WinSCP.exe can't connect to router
Ivan1
RF
when I connect the router via Putty it gives the message
Welcome to IAD2 CLI, you can type '?' to find usage
view @ name of the router>
then I type "sh" and see
 view @ name of the router>sh
BusyBox v1.15.3 () built-in shell (ash)
Enter 'help' for a list of built-in commands.
using WinSCP, the program immediately thinks she's in shell, and gives this message in log:
Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
what i need to set up in WinSCP
that would be after authorization entered the command "sh"
and then the program tried to work with the router for scp
sorry for my English
Ivan1
RF
Re: WinSCP.exe can't connect to router
Hi Martin
I did what you asked in the first post.
But seeing the log, the command "sh" , introduced earlier than it expects router
Ivan1 wrote:
Hi Martin
OK. So I'm afraid that WinSCP is not compatible with the custom system of your router.
