Why should thisnever happen with Session.SynchronizeDirector
codenat
Columbia, SC
Howdy,
So I am using the .net Assembly for a windows service that synchronizes a folder on the FTP server with a folder on the file share server. I found how to do this here: https://winscp.net/eng/docs/library_session_synchronizedirectories
Near the bottom of the sample code is the following:
        if (e.Touch != null)
            if (e.Touch.Error == null)
                Console.WriteLine("Timestamp of {0} set to {1}", e.Touch.FileName, e.Touch.LastWriteTime);
            else
                Console.WriteLine("Setting timestamp of {0} failed: {1}", e.Touch.FileName, e.Touch.Error);
        else
            // This should never happen with Session.SynchronizeDirectories
            Console.WriteLine("Timestamp of {0} kept with its default (current time)", e.Destination);
I don't understand the comment // This should never happen with Session.SynchronizeDirectories.
Could someone explain to me why this should never happen. It currently happens with my service and I am not sure why it shouldn't.
Thanks for your help!
Re: Why should thisnever happen with Session.SynchronizeDirector
Well, it can actually happen, when the server does not support changing remote file timestamp. But that makes the synchronization impossible.
codenat
Columbia, SC
Attached is a log.
I don't know if this is related but the datetime of the file at the end of the process is 4 hours earlier than the current time at the beginning.
If I create a file at 4:00P and then use this program to ftp it, when it ends up in the destination folder, the datetime on the file is 12:00P. If I look at the properties, it says:
created: 30 minutes ago
modified: 5 hours ago
accessed: 30 minutes ago
(see attached jpg)
Nat
Description: snippet of file properties
You are using "remote to local" synchronization (The .Touch will always be null).
While the example is for "local to remote" synchronization.
I have updated the comment to "This should never happen during "local to remote" synchronization"
codenat wrote:
We'll just live with the weird time differences for now.
Not sure how this statement relates.
codenat
Columbia, SC
(see attached jpg)
the attached jpg is in above post
codenat
Columbia, SC
A log was already attached above along with the jpg mentioned that you were asking about.
Do you refer to upload or download? I assume that download, as you do not seem to upload at all.
Can you attach a log file showing two consecutive synchronizations, where at least the first synchronization actually downloads some file (with wrong timestamp) and the second synchronization either downloads the same file or determines that the file does not need synchronization? Please mention a name of the file I should look for in the log file.
