Open terminal / custom commands don't work
dave.dumbeck@...
In version 5.6.0, Open Terminal (Ctrl+T) and custom commands err with "Invalid access to memeory".
In versions 5.6.2 through 5.7.0, Open Terminal (Ctrl+T) and custom commands hang for 15 seconds at "Starting the session..." then err with "Host is not communicating for 15 seconds".
Versions 5.6.1 and 5.5.6 work properly. Windows Vista SP2. Debug logs for 5.6.0 and 5.7.0 attached.
Thanks,
Dave
  • debug570.log (48.71 KB, Private file)
  • debug560.log (38.88 KB, Private file)
Re: Open terminal / custom commands don't work
1) While I do not see any "Invalid access to memory" error in 5.6 log, it was likely this bug:
https://winscp.net/tracker/1187
2) "Host is not communicating for 15 seconds": It's because your server does not respond sensibly to this command:
echo $LANG ; echo "WinSCP: this is end-of-file:$status"
(That's newly used in 5.7)
What shell are you using? What OS is that?
dave.dumbeck@...
C shell on FreeBSD.
LANG: Undefined variable.
dave.dumbeck@...
I set the shell to /bin/sh and now it works.
Thanks,
Dave
