Copying files from remote side failed - Can't open file
murrometz
Russia
Hello! I'm trying to automate downloading backups from my server.
I use Task Scheduler in Windows 7.
Code of script
option batch on
open ftp://...
option transfer binary
get -resume bak.sh С:\backup\new\
What I get
< 2015-03-10 18:08:35.182 150 Here comes the directory listing.
. 2015-03-10 18:08:35.183 drwx------    4 1003     600          4096 Mar 10 03:18 .
. 2015-03-10 18:08:35.183 drwx------    4 1003     600          4096 Mar 10 03:18 ..
. 2015-03-10 18:08:35.184 -rw-------    1 1003     600          1342 Mar 08 21:46 bak.sh
< 2015-03-10 18:08:35.206 226 Directory send OK.
. 2015-03-10 18:08:35.206 Directory listing successful
. 2015-03-10 18:08:35.206 bak.sh;-;1342;2015-03-08T18:46:00.000Z;"1003" [0];"600" [0];rw-------;0
. 2015-03-10 18:08:35.207 File: '/bak.sh' [2015-03-08T18:46:00.000Z] [1342]
. 2015-03-10 18:08:35.207 Copying "/bak.sh" to local directory started.
. 2015-03-10 18:08:35.207 Binary transfer mode selected.
. 2015-03-10 18:08:35.207 Starting download of /bak.sh
> 2015-03-10 18:08:35.208 TYPE I
< 2015-03-10 18:08:35.236 200 Switching to Binary mode.
> 2015-03-10 18:08:35.236 PASV
< 2015-03-10 18:08:35.261 227 Entering Passive Mode (188,225,16,121,118,122).
. 2015-03-10 18:08:35.261 Can't open file 'С:\backup\new\bak.sh'.
. 2015-03-10 18:08:35.261 Copying files from remote side failed.
* 2015-03-10 18:08:35.261 (ExtException) **Can't open file 'С:\backup\new\bak.sh'.**
* 2015-03-10 18:08:35.261 Copying files from remote side failed.
. 2015-03-10 18:08:35.261 Asking user:
. 2015-03-10 18:08:35.261 Error transferring file '/bak.sh'. ("Can't open file 'С:\backup\new\bak.sh'.","Copying files from remote side failed.")
< 2015-03-10 18:08:35.261 Script: Error transferring file '/bak.sh'.
< 2015-03-10 18:08:35.262 Script: Can't open file 'С:\backup\new\bak.sh'.
< 2015-03-10 18:08:35.262 Copying files from remote side failed.
* 2015-03-10 18:08:35.263 (EScpSkipFile) Error transferring file '/bak.sh'.
* 2015-03-10 18:08:35.263 Can't open file 'С:\backup\new\bak.sh'.
* 2015-03-10 18:08:35.263 Copying files from remote side failed.
. 2015-03-10 18:08:35.263 Script: Failed
> 2015-03-10 18:08:35.263 Script: exit
. 2015-03-10 18:08:35.263 Script: Exit code: 1
. 2015-03-10 18:08:35.265 Disconnected from server
The script doesn't create any file.
Is it rights or what ...
Can you help me please! I'm new to winscp scripting and I don't get what's going wrong.
Thank you.
Re: Copying files from remote side failed - Can't open file
murrometz
Russia
ok.
Системе не удается найти указанный путь
is translated as
The system cannot find the path specified
  • log.txt (8.35 KB, Private file)
Does the target path С:\backup\new\ exist? Can the Scheduler account see/access it? Can you do lls С:\backup\new\ before the get?
murrometz
Russia
Thank you for your help!
Yes, i confused cyrillic С and latin C. They are on the same key on the keyboard.
Thank you for your program!
lkystar0729
HK
i have a same problem
. 2020-04-16 16:08:50.279 Directory listing successful
. 2020-04-16 16:08:50.279 ..;D;0;1899-12-30T08:00:00.000Z;0;"" [0];"" [0];---------;0
. 2020-04-16 16:08:50.279 Client statement_20191101.pdf;-;540777;2020-04-09T09:33:40.000Z;3;"admin" [0];"users" [0];rwxrwxrwx;1
. 2020-04-16 16:08:50.279 HSSECB_NANHUA_stockbalance_20191101.csv;-;677;2020-04-09T09:33:36.000Z;3;"admin" [0];"users" [0];rwxrwxrwx;1
. 2020-04-16 16:08:50.279 HSSEC_trade_20191101.txt;-;365;2020-04-09T09:33:26.000Z;3;"admin" [0];"users" [0];rwxrwxrwx;1
. 2020-04-16 16:08:50.279 ZCAI Client_statement_20191031.pdf;-;338769;2020-04-09T09:32:23.000Z;3;"admin" [0];"users" [0];rwxrwxrwx;1
. 2020-04-16 16:08:50.279 Copying 1 files/directories to local directory "Y:\HSS\CCASS\" - total size: 365
. 2020-04-16 16:08:50.279 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask:
. 2020-04-16 16:08:50.279 TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; EncryptNewFiles: Yes; ExcludeHiddenFiles: No; ExcludeEmptyDirectories: No; InclM: ; ResumeL: 0
. 2020-04-16 16:08:50.279 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2020-04-16 16:08:50.279 File: '/CCASS/HSSEC_trade_20191101.txt' [2020-04-09T09:33:26.000Z] [365]
. 2020-04-16 16:08:50.279 Copying "/CCASS/HSSEC_trade_20191101.txt" to local directory started.
. 2020-04-16 16:08:50.279 Binary transfer mode selected.
. 2020-04-16 16:08:50.279 Starting download of /CCASS/HSSEC_trade_20191101.txt
> 2020-04-16 16:08:50.279 TYPE I
< 2020-04-16 16:08:50.279 200 Type set to I.
> 2020-04-16 16:08:50.279 PASV
< 2020-04-16 16:08:50.279 227 Entering Passive Mode (192,168,1,10,217,211)
. 2020-04-16 16:08:50.279 Can't open file 'Y:\HSS\CCASS\HSSEC_trade_20191101.txt'.
. 2020-04-16 16:08:50.279 System Error. Code: 3.
. 2020-04-16 16:08:50.279 The system cannot find the path specified
. 2020-04-16 16:08:50.279 Copying files from remote side failed.
* 2020-04-16 16:08:50.279 (ExtException) **Can't open file 'Y:\HSS\CCASS\HSSEC_trade_20191101.txt'.
* 2020-04-16 16:08:50.279 System Error. Code: 3.
* 2020-04-16 16:08:50.279 The system cannot find the path specified**
* 2020-04-16 16:08:50.279 Copying files from remote side failed.
. 2020-04-16 16:08:50.279 Asking user:
. 2020-04-16 16:08:50.279 Error transferring file '/CCASS/HSSEC_trade_20191101.txt'. ("Can't open file 'Y:\HSS\CCASS\HSSEC_trade_20191101.txt'.
. 2020-04-16 16:08:50.279 The system cannot find the path specified","Copying files from remote side failed.")
< 2020-04-16 16:08:50.279 Script: Error transferring file '/CCASS/HSSEC_trade_20191101.txt'.
< 2020-04-16 16:08:50.279 Script: Can't open file 'Y:\HSS\CCASS\HSSEC_trade_20191101.txt'.
< 2020-04-16 16:08:50.279 System Error. Code: 3.
< 2020-04-16 16:08:50.279 The system cannot find the path specified
< 2020-04-16 16:08:50.279 Copying files from remote side failed.
* 2020-04-16 16:08:50.279 (ESkipFile) Error transferring file '/CCASS/HSSEC_trade_20191101.txt'.
* 2020-04-16 16:08:50.279 Can't open file 'Y:\HSS\CCASS\HSSEC_trade_20191101.txt'.
. 2020-04-16 16:08:50.279 Copying finished: Transferred: 0, Elapsed: 0:00:00, CPS: 0/s
. 2020-04-16 16:08:50.279 Script: Failed
. 2020-04-16 16:08:50.279 Script: Exit code: 1
. 2020-04-16 16:08:50.279 Disconnected from server
