3 New Ideas
Big Fan
3 New Ideas
I want to start by saying thanks you WinSCP is a great program I am a big fan.:D
  • Can you add file segmentation support as me and lots of other people use WinSCP for downloading large files from seedboxes because seedbox companies recommend it and it is a great tool (8 GB plus in not uncommon for a HD film).
  • Also can you add auto download where WinSCP checks every X amount of minutes or hours to see if there is a new file to download and once it has downloaded it deletes the file from the server.
  • Can you also add WinSCP to system services so it starts up in the back ground automatically.
This is for SFTP.
Re: 3 New Ideas
Big Fan wrote:
Can you add file segmentation support as me and lots of other people use WinSCP for downloading large fills from seedboxes because seedbox companies recommend it and it is a great tool (8 GB plus in not uncommon for a HD film).
This request is tracked here:
Issue 513 – Transfer single file using multiple connections
See https://winscp.net/eng/docs/library_example_keep_local_directory_up_to_date
How would that work?
Big Fan
Re: 3 New Ideas
Well if there is any way to get WinSCP to start automatically in the back ground so it can do what I said above without having to be started up by a user each time.
It doesn’t have to be a service there other ways to get it to start which may be better.
And thanks for the other requests.
