Drag n Drop Copy Settings
tclendenen
Every time I drag a file to WinSCP (Explorer View) I am presented with the Copy preferences window. I check the box 'Use Same Settings Next Time' but when I try to drag n drop another file I get the same window and the 'Use Settings Next Time' box is unchecked. I have had the problem with the last few builds including 3.6.8 witch I just downloaded.
Thanks,
Tim
Re: Drag n Drop Copy Settings
See "Environment" tab of Preferences window. There is option in group "Confirmations" named "Drag & drop operations". Uncheck it.
tclendenen wrote:
It is unchecked. I have tried that and have tried changing my configuration storage hoping it would 'reset', but that didn't work either.
OK, it seems not to be working in some situations.
You should have objected sooner, I might have been fixed already in today's release.
tclendenen
Usually when I think I have found a bug and I report it to the project, someone else has already reported it. I guess there is a first time for everything.
Thanks,
Tim
