overwritten files in synchronize, instead change names
@yourappisgreat
1. congratulations, app is great! :)
2. Now about my problem :)
I would like to create a script which will be not erase old files but change them names.
What I mean? Example
a) On HDD I have a file
file.doc
b) script upload file to FTP
c) on HDD file.doc is change.
>> d) on FTP script change name from file.doc to file%date%.doc (or something like that)
e) than from HDD upload file.doc to FTP
Now, my script looks like this:
winscp.com /command "option batch continue" "open backup" "synchronize remote -criteria=time,size X:\path\ /directory" "close" "exit"
But script replace old files on FTP (delete old files, but it could just change names)
Is it possible to do something like this?
Thanks.
Re: overwritten files in synchronize, instead change names
WinSCP cannot do this for you. This is a way too specific request.
You can use synchronize -preview mode with enabled XML logging. Then process the XML log to find a files to be replaced and rename them. Only after that, execute the actual synchronization.
