How do I set option batch abort from .Net
K_G
UK
Hi
How do i set
option batch abort
using C sharp .net code?
I tried the rawswetings, but does not seem to work as i thought it would.
K_G
UK
soryr , so how do i convert
GetFiles() to use .check
as I did look at that, but does not seem to work as example is using TransferResult.
as compiling gives
'Cannont implicitly convert type 'void' to 'WinSCP.TransferOperationResult'
Hope you can help.
