SynchronizationResult "Unknown name"
bobmcrae
United States
I am new to the use of the .NET assembly, but finding it incredibly better than scripting. However, I am having difficulty getting the results of a synchronization, which is actually succeeding. I'd like to see what files are transferred, but cannot seem to iterate through the SynchronizationResult. I am getting a COM error "Unknown name" for everything I have tried.
Perhaps I am misunderstanding that SynchronizationResult has a TransferEventArgsCollection that I can iterate through to get the .FileName of each transferred file. I'd appreciate clarity on the proper method.
I am using AutoIT and here is the code snippet causing issues:
; this works
$syncResult = $session.SynchronizeDirectories($syncMode, $localDir, $remoteDir, False)
If Not $syncResult.IsSuccess Then
SetError(-5)
Return False
EndIf
; here is where I am getting the COM error "Unknown name" for the $syncResult.Transfers object
; I have tried $syncResult.TransferEventArgsCollection, but that results in the same thing
For $transferItem in $syncResult.Transfers
ConsoleWrite($transferItem.FileName & @CRLF)
Next
Thanks in advance.
bobmcrae
United States
perfect: thank you
Using Uploads I was able to see that the COM error is avoided and I get the result I was looking for. Thank you.
I am coming at this as a beginner, so I was confused by the documentation, which lead me to believe that the
SynchronizeDirectories object returned a SynchronizationResult object which returned TransferEventArgsCollection (an object). I see now under TransferEventArgsCollection, is listed Uploads (and Downloads). However, can you help me (and others) understand at what point I use the object versus the test result (Uploads)?
Re: perfect: thank you
That's correct.
The TransferEventArgsCollection is a type of .Downloads and .Uploads properties of SynchronizationResult result class/object.
