Problem with deleting files
mazzic
Texas
I have a problem with WinSCP deleting files on a specific server. The files are in a directory and when I change to the directory and try to delete the file it fails. I noticed that even though I have changed the working directory the delete command is issued with the directory and file name. IE DELE /Outgoing/file.txt
If I use the Execute command window and issue a DELE file.txt, it works.
Is there a setting that I can change to make WinSCP not append the directory name?
Attached is a debug of the session were using the GUI I tried to delete the file, followed by using the execute command window.
Thanks.
Re: Problem with deleting files
Is this only about delete? Can you do other operations with the file (rename, download, etc)? Can you post a log file for these too?
