ErrorTransfering javascript files frm host->local computer
MrBaseball34
When transfering javascript files from my remote computer to my local computer, I've been getting exception windows shown in the attached image.
How can I prevent this from happening?
Description: Excepiton windows
Re: ErrorTransfering javascript files frm host->local computer
Result on a further conversation over an email:
Though from your video, I can see, that it behaves as if the .js has a drop handler associated on your system.
In such case, you can drop other files to such files and the handler will try to process the dropped file using the file you drop it on.
You should get the same behavior even when dropping a local .js file to another local .js file in Windows Explorer.
It is the same "feature" that allows you to drop a .docx file on winword.exe to open it; or drop any file on .zip archive to add it to the archive.
