Bad mapping of UTF8 character?
Medalha
I have been using WinSCP together with Putty for some years. I was very happy with the extended UTF8 support offered by WinSCP in the later versions. Meanwhile, it seems to me that an error persists in the mapping of some UTF8 characters.
One of the user groups in me servers is called "gráficos". This is correctly show by Putty. However, WinSCP shows it as "gráficos".
Both programs are configured for UTF8.
Is this a bug? If it is, would one of the developers be so kind as to fix it?
Thank you for the awesome work.
Re: Bad mapping of UTF8 character?
I am referring, of course, to the owner and group permissions as shown in the WinSCP listings of files As a matter of fact, I just discovered that other accented characters also show incorrectly. For example, "ó" shows as "ó".
Medalha
I must add that the file names themselves show correctly, only owner and group permissions show incorrect characters. As I said before, Putty shows the correct characters at the exact same positions.
Medalha
Here goes the log. It has been anonymized, otherwise it is complete.
Thank you.
  • WinSCP.log (8.62 KB, Private file)
Description: Log file showing the file permissions with wrong characters. As I said before, file names are not affected.
Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
Medalha
Persistent bug in display of user and group permissions
I just found that when a file owner's name contains a space WinSCP will send everything after the first space to the column for group permissions. For example, when owner is "domain admins" and group is "domain admins", these permissions will appear as owner "domain" and group "admins domain admins". Another example: "enterprise read-only domain controllers" + "domain admins" will show as "enterprise" + "read-only domain controllers domain admins".
I am posting in this thread because I suppose it is related to the previously reported bug 1288/1212.
This bug is present up to version 5.80 Beta.
I must add that Putty 0.66 shows the permissions correctly.
Thank you again four your outstanding work.
Medalha
Re: Persistent bug in display of user and group permissions
New topic started under the title "Incorrect display of user and group permissions when file owner's name contains one or more spaces".
Thank you.
