Dll cannot initialize external console.
Tarinishah
Seattle, WA
I have a block of code that uploads a txt file to remote SFTP.
However, I am getting the below error.
WinSCP.SessionRemoteException: Cannot initialize external console. at WinSCP.SessionLogReader.Read(LogReadFlags flags) at WinSCP.ElementLogReader.Read(LogReadFlags flags) at WinSCP.SessionElementLogReader.Read(LogReadFlags flags) at WinSCP.CustomLogReader.TryWaitForNonEmptyElement(String localName, LogReadFlags flags) at WinSCP.CustomLogReader.WaitForGroupAndCreateLogReader() at WinSCP.Session.Open(SessionOptions sessionOptions) at XMLPostoverFTP.Class1.getFTP()
This is the block of code-
Protocol = Protocol.Sftp,
HostName = "sftpimfs.ironmountain.com",
UserName = "Zuza",
Password = "frYG2CY9",
PortNumber = 22,
SshHostKeyFingerprint = "ssh-rsa 2048 a8:4c:12:ef:2f:29:c0:62:b7:37:5c:d4:73:0a:55:7b"
session.ExecutablePath = null;
session.SessionLogPath = null;
session.Open(sessionOptions);
transferOptions.TransferMode = TransferMode.Binary;
transferOptions.FilePermissions = null; //Permissions applied to remote files;
transferOptions.PreserveTimestamp = false; //Set last write time of
//destination file to that of source file - basically change the timestamp
//to match destination and source files.
transferOptions.ResumeSupport.State = TransferResumeSupportState.Off;
TransferOperationResult transferResult;
transferResult = session.PutFiles("/ZUZAUpload.txt", "/Outbox/", false, transferOptions);
transferResult.Check();
Would be great to get some help, on where am I going wrong.
Thanks[/i]
Re: Dll cannot initialize external console.
Please attach a full debug log file showing the problem (using the latest version of WinSCP).
To generate log file, set Session.DebugLogPath. Submit the log with your post as an attachment. If you do not want to post the log publicly, you can mark the attachment as private.
Can you elaborate on an environment you are getting the error with?
