Help setting $transferOptions.FilePermissions in PowerShell
notbroken
I need to set the file permissions to octal 666 in PowerShell.
$transferOptions.FilePermissions = ?
I am new to PowerShell and am trying to work through this "Create new instance of FilePermissions and set FilePermissions.Octal to a value of the switch."
Any help/guidance would be appreciated
rams
Powershell winscp filepermissions
I have to use the following:
Write-Host "transferOptions.FilePermissions Object Creation ..."
$transferOptions.Octal = New-Object WinSCP.FilePermissions
$transferOptions.Octal = "0775"
Why?
Reason: $transferOptions.FilePermissions is NOT valid property error?
Write-Host "Uploading $line ..."
$transferResult = $session.PutFiles($line, $remotePath, $false, $transferOptions).Check()
Please help?
Re: Powershell winscp filepermissions
As shown above, this is the correct code:
$transferOptions.FilePermissions = New-Object WinSCP.FilePermissions
$transferOptions.FilePermissions.Octal = "0775"
Alternatively, like this:
$transferOptions = New-Object WinSCP.TransferOptions -Property @{
    FilePermissions = New-Object WinSCP.FilePermissions -Property @{ Octal = "0775" }
You can have the latter code generated by WinSCP GUI:
https://winscp.net/eng/docs/ui_generateurl#code
