Can't move locally or delete local files after upload
qb
Ok, the subject says it all.
After I upload files to the server I can't move or delete the files on the local box.
Is there some permissions I am missing somewhere?
Here are some lines from the debug log that might be useful:
<failure>
<message>Can't get attributes of file 'c:\dir\test.txt'.</message>
<message>The file path does not exist or is invalid.
Error code: 10
Error message from server (en): The file path does not exist or is invalid.</message>
</failure>
Thanks for any help.
Re: Can't move locally or delete local files after upload
