List index out of bounds (-1) - System::Classes::TList::Get
Goto page
1, 2, Next
smithb895@...
I imported a backup of some Sites from a .INI file while I had a current connection open. I believe the configs that were imported overwrote the site config for the currently open connection. Hope this helps.
WinSCP 5.7
[005635F5] System::Classes::TList::Get
Re: List index out of bounds (-1)
1450jhk@...
List index out of bounds (0)
WinSCP 5.7.1
스택 추적:
[01243685] System::Classes::TList::Get
[012F9B3A] Customdirview::TCustomDirView::DDProcessDropped
[0131F3EB] Dragdrop::TDragDrop::WndMethod
[01260708] System::Classes::_18201
[76FC7831] USER32.DLL.CallNextHookEx
[76FC7A95] USER32.DLL
[76FC9889] USER32.DLL
[76FC98EC] USER32.DLL.DispatchMessageW
1450jhk@...
How to reproduce
ZIP - <invalid hyperlink removed by admin>
Compressed (zipped) program - <invalid hyperlink removed by admin>
Download this file.
WinSCP program to open the file directly with a drag-and-drop file transfers.
OS - Windows 8.1 Professional Service Pack 1
10 of 10 times all the problems that occurred.
Re: Unlimited error reproducible
Thanks for your report. Will try to reproduce it. Will contact you on your email address after.
1450jhk@...
Q : Did I understand right that you have the cm-11.0.zip file in the remote directory and you drag & drop the file to the BandiZip application? I assume you have "Use temporary folder" drag&drop mode enabled, right?
A : Yes. I use drag&drop and check Use shell extension.
Strange. Do not reproduce the debug version.
However, the full version is an error.
Once you upload the file to. Trying to be helpful but I don't know.
Description: Reproduced, but strangely not reproduce
1450jhk@...
Thanks. I have sent your a dev (non-debug) version for testing.
OK. Does the error pop up.
However, Windows 8.1 compatibility problems.
1450jhk@...
Note : I using Installation Package.
Development version is not in the Installation Package, it may not be an error.
After the reboot the computer I tried to reproduce the error has not been reproduced in the development version.
nephaste@...
WinSCP 5.7
[016535F5] System::Classes::TList::Get
[01709AAA] Customdirview::TCustomDirView::DDProcessDropped
[0172F35B] Dragdrop::TDragDrop::WndMethod
[01670678] System::Classes::_18201
[763862F7] USER32.dll
[76386D35] USER32.dll
[763877BF] USER32.dll
[76387885] USER32.dll.DispatchMessageW
1450jhk@...
Has been reproduced again :shock:
Sent me
<Image : <invalid hyperlink removed by admin> >
WinSCP 5.7.2
(00322869) System::Classes::TList::Get
(003D8D1E) Customdirview::TCustomDirView::DDProcessDropped
(003FE5CF) Dragdrop::TDragDrop::WndMethod
(0033F8EC) System::Classes::_18201
(000080CC) USER32.DLL
(0000966A) USER32.DLL
(000096DB) USER32.DLL.DispatchMessageW[url][/url] :?
Please send me a debug version.
Re: List index out of bounds (0)
1450jhk@...
WinSCP1038trace.txt
Delete recovery-philz folder, and recreate, drag&down -> error
WinSCP10B4trace.txt
Create WinSCP folder, drag&down -> error
P.S - If you set the Bandizip settings in the quick drag&down errors.
  • winscp20150422d.zip (5.07 MB, Private file)
Thanks. Though you have attached debug binaries, instead of the trace files.
nour@...
List index out of bounds (0) - System::Classes::TList::Get
WinSCP 5.7.4
(00322F09) System::Classes::TList::Get
(003D93D2) Customdirview::TCustomDirView::DDProcessDropped
(003FECBF) Dragdrop::TDragDrop::WndMethod
(0033FF8C) System::Classes::_18201
(000152F7) USER32.dll
(00015D35) USER32.dll
(000167BF) USER32.dll
Re: List index out of bounds (0) - System::Classes::TList::Get
darth_revan43
WinSCP 5.7.5
(00323199) System::Classes::TList::Get
(003D9662) Customdirview::TCustomDirView::DDProcessDropped
(003FEF4F) Dragdrop::TDragDrop::WndMethod
ps@...
I drag and dropped a File from Visual Studio Code (left window "working files") to WinSCP
WinSCP 5.7.5
cn8hb@...
WinSCP 5.7.4
Trace de la pile :
I have sent you an email to address you have used to register on this forum.
contact@...
WinSCP 5.7.5
Trace de la pile :
(00033921) USER32.dll
(0001378B) USER32.dll
(0001308C) USER32.dll
martin@...
Using Gmail, I selected a .jpg attachment and dragged it to a WinSCP session. Problem occurs consistently.
WinSCP 5.7.5
WinSCP 5.7.5
Thanks for your report. I've sent you an email.
WinSCP 5.7.5
This is actually a known problem:
https://winscp.net/tracker/1361
gerber@...
Error occurred during logging. It's been turned off - System::Classes::TList::Get
When logging to a window is enabled and I connect to this WebDAV site, the error occurs.
Log & screen shot of folder listing is attached.
WinSCP 5.7.7
Error occurred during logging. It's been turned off.
List index out of bounds (168)
(00323519) System::Classes::TList::Get
(0061204B) TLogMemo::WMLogUpdate
(00612D16) TLogMemo::Dispatch
(000167CE) USER32.dll
(0061184E) TLogMemo::SessionLogChange
(006CB799) TSessionLog::AddException
(0070FC18) TTerminal::ShowExtendedException
  • WinSCP folder screen - box.gif (46.86 KB, Private file)
  • Sites-Box.com-WebDAV.log (16.45 KB, Private file)
roy.colbert@...
I enabled logging. When I closed the dialogue, I received the error below.
WinSCP 5.7.7
(00612429) TLogMemo::SetParent
(0075BCD5) RequireLogForm
(007700F5) TPreferencesDialog::Execute
(0076F6B5) DoPreferencesDialog
(000A1DEF) CopyParamListPopupClick
(0073FC74) TCopyDialog::CopyParamClick
(0041C8B3) Tb2item::TTBCustomItem::Click
(007E0F15) C4799_0
(007E24EF) _ReThrowException
(0075BC7C) CreateLogForm
Re: List index out of bounds (-1) - System::Classes::TList::Get
Part of this errors were resolved in 5.8, as the log window is no longer available.
jonny@...
WinSCP 5.9
(003555C9) System::Classes::TList::Get
(00248BFB) Vcl::Controls::TControl::DragOver
(00249194) Vcl::Controls::TControl::DoDragMsg
matchman72@...
close multiple tabs in winscp by mouse middle click, the error shown after closing around 5 - 6 tabs
WinSCP 5.9
(003B1034)
(0086216E)
(008641D6)
(00860F90)
(00045CC6) ntdll.dll.RtlRaiseStatus
(00045B52) ntdll.dll.KiUserExceptionDispatcher
(006A5ABE)
(006A5E4B)
(006A5F37)
(006A5F90)
(0008AAFB)
(0024A17C)
(0024A214)
(0024A3F9)
(0024E715)
(0024DD5C)
(0037264C)
(0001B4C4) USER32.dll
(0001B5C2) USER32.dll
(00010B04) USER32.dll
(00010B2A) USER32.dll.CallWindowProcW
(0042BD7F)
(0037264C)
(0001BBFB) USER32.dll
(0001BC53) USER32.dll.DispatchMessageW
(006A5F37)
(006A5F90)
(0008AAFB)
(0024A17C)
(0024A214)
(0024A3F9)
(0024E715)
(0024DD5C)
(0037264C)
(0042BD7F)
(0037264C)
(003555C9)
(003555C9)
(0008AAFB)
(0024A17C)
(0024A214)
(0024A3F9)
(0024E715)
(0024DD5C)
(0037264C)
(0042BD7F)
(0037264C)
nga911@...
WinSCP 5.9.3
(0035607D) System::Classes::TList::Get
michail.krasnoschokov@...
WinSCP 5.9.3
Трассировка стека:
liamgbox@...
WinSCP 5.9.2
Трассировка стека:
(00355B69) System::Classes::TList::Get
(0008AF2F) TTerminalManager::FreeActiveTerminal
(0024A690) Vcl::Controls::TControl::MouseDown
(0024A728) Vcl::Controls::TControl::DoMouseDown
(0024A90D) Vcl::Controls::TControl::WMMButtonDown
(0024E270) Vcl::Controls::TWinControl::MainWndProc
(0002C2B1) USER32.dll
(0000D885) USER32.dll
(0000CF12) USER32.dll.CallWindowProcW
(0042C32F) Dragdrop::TDragDrop::WndMethod
(0000D1DF) USER32.dll
michail.krasnoschokov@... wrote:
WinSCP 5.9.3
Трассировка стека:
vijayang@...
WinSCP 5.9.3
(00020140) TCustomScpExplorerForm::PasteFromClipBoard
(00037BF4) TNonVisualDataModule::ExplorerActionsExecute
(003B521C) System::Actions::TContainedActionList::ExecuteAction
(0019C395) Vcl::Actnlist::TCustomAction::Execute
ty@...
WinSCP 5.9.3
protsyuk.ivan@...
I've just downloaded WinSCP on a PC where it hasn't been installed before. After the installation has finished, I set "Run WinSCP" flag in the installation wizard. The wizard closed, and I saw an error message box with a message shown below.
WinSCP 5.9.4
(003561A9) System::Classes::TList::Get
teddy@...
WinSCP 5.9.6
(003564E1) System::Classes::TList::Get
tbm@...
After installing WinSCP on a Windows 10 PC -- where it had not been previously installed -- the install Wizard gave this message. WinSCP seems to open fine.
WinSCP 5.9.6
WinSCP 5.9.6
illvous@...
Steps for reproducing the error.
1. Run WinSCP
2. Hide a popup window that session selector by pressing a key "Esc"
3. Pressing the keyboard shortcut "Ctrl + Tab"
4. The error message was shown
Thanks.
WinSCP 5.11.1 (lang. with Japanese)
スタック トレース:
(0035EB11) System::Classes::TList::Get
1. Run WinSCP
Thanks.
スタック トレース:
Thanks for your post.
https://winscp.net/tracker/1585
hrvoj3e@...
List index out of bounds (3) - System::Classes::TList::Get
First error popup was something like "Cannot write to log file - another process is using the same file"
See first attachment. Do you think it is because I have the same session opened multiple times ant it uses the same log file on disk.
System Error. Code: 32.
The process cannot access the file because it is being used by another process
WinSCP 5.11.3
(0035EC39) System::Classes::TList::Get
  • 2018-01-26.174253.screenshot.png (16.19 KB, Private file)
Description: after clicking OK about 10 times it crashes
  • 2018-01-26.173832.screenshot.png (92.32 KB, Private file)
ayantuf@...
Invalid access to memory - System::Classes::TList::Get
WinSCP 5.11.3
(0035EC2A) System::Classes::TList::Get
(000624F6) ntdll.dll
sebudin@...
WinSCP 5.13.2
(003631A9) System::Classes::TList::Get
(00020B29) TCustomScpExplorerForm::RemoteFileControlDDQueryContinueDrag
(0041F572) Customdirview::TCustomDirView::DDQueryContinueDrag
(004419DA) __stdcall Dragdrop::TDropSource::QueryContinueDrag
(0008BB0E) OLE32.DLL
(0008C3DE) OLE32.DLL.DoDragDrop
(00443BB3) Dragdrop::TDragDrop::ExecuteOperation
(0041C39F) Customdirview::TCustomizableDragDropFilesEx::Execute
(0067A21A) TUnixDirView::DDDragDetect
(0041CA9C) Customdirview::TCustomDirView::CNNotify
(0025639D) Vcl::Controls::TControl::WndProc
(0025AEE1) Vcl::Controls::TWinControl::WndProc
(0029EE0F) Vcl::Comctrls::TCustomListView::WndProc
(0025B047) Vcl::Controls::_17076
(0025A528) Vcl::Controls::TWinControl::MainWndProc
(0003AE69) USER32.dll
(00037335) USER32.dll
(00036ED5) USER32.dll
(00039627) USER32.dll
(0006A96B) ntdll.dll.KiUserCallbackDispatcher
(0003947D) COMCTL32.DLL
(0019217D) COMCTL32.DLL
(0005BDAA) COMCTL32.DLL
(0002D8C2) COMCTL32.DLL
(0025AFF2) Vcl::Controls::TWinControl::DefaultHandler
(0041E2C4) Customdirview::TCustomDirView::WMRButtonDown
(00049AD7) COMCTL32.DLL
(00049B76) COMCTL32.DLL
(00049930) COMCTL32.DLL
(004430CF) Dragdrop::TDragDrop::WndMethod
(00036BE9) USER32.dll
em2015@...
WinSCP 5.13.3
(003632ED) System::Classes::TList::Get
(00020B7D) TCustomScpExplorerForm::RemoteFileControlDDQueryContinueDrag
(0041F6B6) Customdirview::TCustomDirView::DDQueryContinueDrag
(00441B1E) __stdcall Dragdrop::TDropSource::QueryContinueDrag
(0003AE23)ole32.dll
(0003F498)ole32.dll
(0008F748)user32.dll
(00090B78)user32.dll
(00090D8B)user32.dll
(0005DB44)user32.dll
em2015@...
WinSCP 5.13.3
(0003AE23)ole32.dll
(0003F498)ole32.dll
vincezgoh@...
WinSCP 5.13.3
Re: List index out of bounds (3) - System::Classes::TList::Get
dave.aaronson@...
WinSCP 5.13.1
(00361CDD) System::Classes::TList::Get
(007802B6) TSFTPFileSystem::UnreserveResponse
(0077A773) TSFTPFileSystem::~TSFTPFileSystem
(007B153F) TTerminal::~TTerminal
(003EF348) System::TObject::Free
(007296B5) TManagementScript::~TManagementScript
(000557BC) TConsoleRunner::Run
(0005B9E2) Console
(000E0A32) Execute
(000024A8) wWinMain
(008B842D) __wstartup
(00038800) ntdll.dll
(000387D0) ntdll.dll
(0040F059) System::Generics::Collections::TList__1<Vcl::Controls::TImageList *>::
(008BA3F6) C5101_0
(008BC45E) ____ExceptionHandler
(008B9218) __ExceptionHandler
(0006248E) ntdll.dll
(008B91FF) __ExceptionHandler
(008BA1B4) C5067_0
(008BA3F6) C5101_0
Re: Invalid access to memory - System::Classes::TList::Get
adam.hajdany@...
WinSCP 5.13.7
(00364019) System::Classes::TList::Get
(00256237) Vcl::Controls::TControl::DragOver
(002567D0) Vcl::Controls::TControl::DoDragMsg
I was dragging tabs from left to right and the other way around.
When I dragged a tab to the right, above the session tabs and out of its inner boundary, then this error occurred. I attempted to release the dragged tab above the left-pointing arrow at the very right of the session tab group. The error popup appeared twice in a row for a single drag-and-release event.
keenicky@...
WinSCP 5.16
(00387159) System::Classes::TList::Get
(0002C1BD) TCustomScpExplorerForm::CloseSessionTab
(00279631) Vcl::Controls::TWinControl::WndProc
(00278C78) Vcl::Controls::TWinControl::MainWndProc
(003A4294) System::Classes::_18201
(000438E9) USER32.dll
(00025137) USER32.dll
(0047B2AB) Dragdrop::TDragDrop::WndMethod
(00024289) USER32.dll
biggsmi@...
Tried closing a tab bug got an error. Every attempt to close it would get this List index out of bounds. The problem tab disappeared on it's own when I attempted to open a new tab.
WinSCP 5.16
(00387159)
(0002C1BD)
(00279631)
(00278C78)
(003A4294)
(00043749) USER32.dll
(000250B7) USER32.dll
(0047B2AB)
(003A4294)
(00024209) USER32.dll
Chris.eldering@...
WinSCP 5.15.5
(00386D11) System::Classes::TList::Get
(00087D6F) ntdll.dll
(00237A7D) Vcl::Forms::TCustomForm::CloseQuery
(002791E1) Vcl::Controls::TWinControl::WndProc
(002336A8) Vcl::Forms::TCustomForm::WndProc
Chandrasekaran.Michael@...
WinSCP 5.16.1
(00386F59) System::Classes::TList::Get
(0002C1D5) TCustomScpExplorerForm::CloseSessionTab
(00279431) Vcl::Controls::TWinControl::WndProc
(00278A78) Vcl::Controls::TWinControl::MainWndProc
(003A4094) System::Classes::_18201
(0047B097) Dragdrop::TDragDrop::WndMethod
fx305@...
WinSCP 5.15.5
Трассировка стека:
(00386D09) System::Classes::TList::Get
(0002B405) TCustomScpExplorerForm::CloseSessionTab
(00278828) Vcl::Controls::TWinControl::MainWndProc
(000436C9) USER32.dll
(0047AE07) Dragdrop::TDragDrop::WndMethod
wulvxian@...
无效的内存访问。 - System::Classes::TList::Get
WinSCP 5.15.5
无效的内存访问。
(00386CFA) System::Classes::TList::Get
monomax00@...
WinSCP 5.17
Трассировка стека:
(0038742D) System::Classes::TList::Get
(0002C241) TCustomScpExplorerForm::CloseSessionTab
(00279905) Vcl::Controls::TWinControl::WndProc
(00278F4C) Vcl::Controls::TWinControl::MainWndProc
(003A4568) System::Classes::_18201
(0001FD22) USER32.dll
(0047B66F) Dragdrop::TDragDrop::WndMethod
charles.f.nelson@...
List index out of bounds (4) - System::Classes::TList::Get
lots of error boxes "in use some where else"
WinSCP 5.15.9
(00386D41) System::Classes::TList::Get
skubach@...
WinSCP 5.17.1
Трассировка стека:
(0038743D) System::Classes::TList::Get
(00278F5C) Vcl::Controls::TWinControl::MainWndProc
(00043389) USER32.dll
(00023F87) USER32.dll
(000234DA) USER32.dll.CallWindowProcW
(0047B67F) Dragdrop::TDragDrop::WndMethod
(000230D9) USER32.dll
evoisat@...
I did the same things that I always do. having open two tabs with two connections to the same server but different accounts.
When I tried to close the second one just now, as I often do, this error came up. The tab was not active, I directly clicked on the x with the tab in the background.
Never happened before, I am not aware of anything i have done differently than the 1000 times before.
WinSCP 5.17.1
(00043449) USER32.dll
dudarev_97@...
WinSCP 5.17.2
Трассировка стека:
(0027537C) Vcl::Controls::TControl::MouseDown
(00275414) Vcl::Controls::TControl::DoMouseDown
(002755F9) Vcl::Controls::TControl::WMMButtonDown
(00015307) USER32.dll
(00015D45) USER32.dll
(0001FD6A) USER32.dll
(0001FD90) USER32.dll.CallWindowProcW
(000167D2) USER32.dll
skubach@...
WinSCP 5.17.3
Трассировка стека:
(003876A5) System::Classes::TList::Get
(0002C221) TCustomScpExplorerForm::CloseSessionTab
(00279B7D) Vcl::Controls::TWinControl::WndProc
(002791C4) Vcl::Controls::TWinControl::MainWndProc
(0047B94F) Dragdrop::TDragDrop::WndMethod
fajarra@...
WinSCP 5.17.3
(0001FD3A) USER32.dll
Thanks for your reports.
RePa69@...
WinSCP 5.17.3
(000AB6BB) TTerminalManager::FreeActiveTerminal
jerry.prodoehl@...
List index out of bounds (5) - System::Classes::TList::Get
WinSCP 5.17
(00007FFF) USER32.dll.CallNextHookEx
(0000A02A) USER32.dll
(000084B7) USER32.dll
(000086B7) USER32.dll
(0003F404) ntdll.dll.KiUserCallbackDispatcher
(0000E2BD) USER32.dll.SendMessageTimeoutW
(000B9FC5) UXTHEME.DLL
(000B3460) UXTHEME.DLL
(000A67E0) UXTHEME.DLL
(000A699C) UXTHEME.DLL
(0000E0AC) USER32.dll.EnumChildWindows
(000533A6) USER32.dll.EnumDesktopWindows
(000A6854) UXTHEME.DLL
(0003B5BD) USER32.dll
(000533D0) USER32.dll.EnumDesktopsW
(000A692F) UXTHEME.DLL
(000B34B0) UXTHEME.DLL
(0009D35C) UXTHEME.DLL
(0000A00D) USER32.dll
(000097FA) USER32.dll
(0000986B) USER32.dll.DispatchMessageW
a@...
WinSCP 5.17.5
Traza de la pila:
(0038796D) System::Classes::TList::Get
(0002C225) TCustomScpExplorerForm::CloseSessionTab
(00279E45) Vcl::Controls::TWinControl::WndProc
(0027948C) Vcl::Controls::TWinControl::MainWndProc
(003A4AA8) System::Classes::_18201
(0047BD83) Dragdrop::TDragDrop::WndMethod
miedziumaly@...
WinSCP 5.17.5
(0027432B) Vcl::Controls::TControl::DragOver
(002748C4) Vcl::Controls::TControl::DoDragMsg
by.palermo@...
WinSCP 5.16.2
Yığın izleme:
(00386FD9) System::Classes::TList::Get
(0002C235) TCustomScpExplorerForm::CloseSessionTab
(002794B1) Vcl::Controls::TWinControl::WndProc
(00278AF8) Vcl::Controls::TWinControl::MainWndProc
(003A4114) System::Classes::_18201
(0003AF19) USER32.dll
(000373E5) USER32.dll
(0047B1B7) Dragdrop::TDragDrop::WndMethod
(00036C99) USER32.dll
giorgiogiuse04@...
WinSCP 5.17.6
(0038798D) System::Classes::TList::Get
(00279E65) Vcl::Controls::TWinControl::WndProc
(002794AC) Vcl::Controls::TWinControl::MainWndProc
(000434B9) USER32.dll
(00023FF7) USER32.dll
(0002354A) USER32.dll.CallWindowProcW
(0047BDAB) Dragdrop::TDragDrop::WndMethod
(00023149) USER32.dll
nourihaj@...
WinSCP 5.17.6
Trace de la pile :
bogdanstefan@...
List index out of bounds (1) - System::Classes::TList::Get
Hi Team,
First time I've seen this error - occurred when I resumed the machine from Hibernate.
Best,
Bogdan
WinSCP 5.17.7
(00387A6D) System::Classes::TList::Get
(00E085D5) CreateMoreMessageDialog
(000EEB4F) CreateMessageDialogEx
(000EF3C0) CreateMoreMessageDialogEx
(000EF53A) MoreMessageDialog
(000F1088) ExceptionMessageDialog
(000BD7D4) ShowExtendedExceptionEx
(000BCC08) ShowExtendedException
(00002658) wWinMain
(00F8663D) C5164_0
(00066AF2) ntdll.dll
(00066AB9) ntdll.dll
tpham@...
WinSCP 5.17.7
(0002C265) TCustomScpExplorerForm::CloseSessionTab
(00279F45) Vcl::Controls::TWinControl::WndProc
(0027958C) Vcl::Controls::TWinControl::MainWndProc
(0003AAF9) USER32.dll
(00036E75) USER32.dll
(00016E48) USER32.dll.CallWindowProcW
(0047BF0F) Dragdrop::TDragDrop::WndMethod
(00036729) USER32.dll
(0003650B) USER32.dll.DispatchMessageW
nigelcannings@...
WinSCP 5.17.7
(00002658) wWinMain
(00F8663D) C5164_0
(00066C22) ntdll.dll.RtlGetAppContainerNamedObjectPath
(00066BEF) ntdll.dll.RtlGetAppContainerNamedObjectPath
rvence@...
WinSCP 5.17.7
Traza de la pila:
(000435C9) USER32.dll
(000240D7) USER32.dll
(0002362A) USER32.dll.CallWindowProcW
(00023229) USER32.dll
(0002300B) USER32.dll.DispatchMessageW
shivpoojan.dubey@...
WinSCP 5.17.7
sadqwe@...
List index out of bounds (2) - System::Classes::TList::Get
WinSCP 5.17.8
(00388789) System::Classes::TList::Get
vigmkrtchyan@...
WinSCP 5.17.8
(0002C279) TCustomScpExplorerForm::CloseSessionTab
(0027AC61) Vcl::Controls::TWinControl::WndProc
(0027A2A8) Vcl::Controls::TWinControl::MainWndProc
(0003DF69) USER32.dll
(00034EF5) USER32.dll
(000345D2) USER32.dll
(00032766) USER32.dll.CallWindowProcW
(0047CC2B) Dragdrop::TDragDrop::WndMethod
(00032C55) USER32.dll
(00032A1B) USER32.dll.DispatchMessageW
a@...
WinSCP 5.17.9
(00388819) System::Classes::TList::Get
(0027ACF1) Vcl::Controls::TWinControl::WndProc
(0027A338) Vcl::Controls::TWinControl::MainWndProc
(0047CC8B) Dragdrop::TDragDrop::WndMethod
sound.of.music@...
WinSCP 5.17.9
Stapelverfolgung:
(0003DF59) USER32.dll
(00034ED5) USER32.dll
(000345B2) USER32.dll
(00032756) USER32.dll.CallWindowProcW
(00032C45) USER32.dll
(00032A0B) USER32.dll.DispatchMessageW
csads33355@...
WinSCP 5.17.9
Трассировка стека:
(0000D895) USER32.dll
(0000CF22) USER32.dll.CallWindowProcW
(0000D1EF) USER32.dll
tyahin@...
WinSCP 5.17.8
Трассировка стека:
(000437A9) USER32.dll
(000242A7) USER32.dll
(000237FA) USER32.dll.CallWindowProcW
(000233F9) USER32.dll
mitch.doraty@...
I had 6 WINSCP connections up. I was editing a single file each connection. Upon completing that task I was closing out of each connection fairly quick and that's when the error message popped up.
--Did not try to reproduce the problem
WinSCP 5.17.9
(00034EC5) USER32.dll
(000345A2) USER32.dll
(00032746) USER32.dll.CallWindowProcW
(00032C35) USER32.dll
furutani-kazuki@...
WinSCP 5.17.10
スタック トレース:
(0038883D) System::Classes::TList::Get
(0047CCAF) Dragdrop::TDragDrop::WndMethod
anj.rbk7@...
WinSCP 5.17.10
apeman1213@...
WinSCP 5.17.10
(002751FB) Vcl::Controls::TControl::DragOver
(00275794) Vcl::Controls::TControl::DoDragMsg
boyebola@...
I left sessions on the system for a long time. I came back and tried to close the session and got the error
wayne@...
WinSCP 5.17.10
(0003DEB9) USER32.dll
(00034E75) USER32.dll
(00034552) USER32.dll
(00032BE5) USER32.dll
baptistelaureau5@...
WinSCP 5.17.7
Trace de la pile :
Goto page
1, 2, Next
