Append upload over SFTP?
captain_planet
Hi.
I'm using the .Net library and uploading via SFTP. I see there is a command line option for -append, however I can't find the option to set the upload to append from the .Net assembly? Is this possible?
Thanks.
Re: Append upload over SFTP?
No there's not any, yet.
You can download .NET assembly source code and modify Session.PutFiles to support it. It's very simple.
