Filemask date time problem
richtrot
When I use the file mask with a date and time nothing transfers
my file mask is as follows
transferOptions.FileMask = "*.xml<=" + strTimeMask ;
when the above translates to *.xml<=2015-02-04 all files < or = are transferred.
when the above translates to *.xml<=2015-02-04 03:27:11 nothing is transferred.
I think it has something to do with the space between the time and date but do not know how to resolve this problem.
thanks for any help
Re: Filemask date time problem
Bharath1988
File Masking
I am not able to use file masking in winscp 5.9.6, may i know the reason.
Which version of winscp will support file masking.
Re: File Masking
You have to tell us more. And show us your code.
Tommy G
thanks for any help
You are right, it is the space that is throwing things off. So you just just need to put the whole file mask in quotes, and it will work.
So assuming you're using C#...
 transferOptions.FileMask =  "\"*.xml<=" + strTimeMask + "\"";
Which translates to...
"*.xml<=2015-02-04 03:27:11" as your mask
No, the quotes may not be there, they actually break the mask.
This is the correct code:
transferOptions.FileMask =  "*.xml<=" + strTimeMask;
If you have a different experience, please attach a full session log file showing the problem (using the latest version of WinSCP).
