Files were moved to a nonexistent directory using WinSCP and
Hi everyont. I tried to move some files to a directory using WinSCP GUI (move to...), but I did a mistake and typed a non-existent directory. The files disappeared and appeared one file without extension. I can't open it. How can I get back my files?
Re: Files were moved to a nonexistent directory using WinSCP and
What protocol are you using?
You probably moved all the files into one, overwriting one by one in the process. I'm afraid, there's no way to recover the files. Maybe only using some "undelete" on the server.
