Cant delet file
Kami
Cant delet file
If I try to delete a file with non standard letters, the program says:
invalid characters in scp command!
here:ß"
try using a wildcard to match this file/directory.
I don't understand what I have to do. I can't rename or delete it, what is a wildcard? Can you explain me, where to find it in program? I am not sure, probably the server do not support it?
Re: Cant delet file
The message you have posted comes from the server, not from WinSCP. You cannot use wildcards in WinSCP to delete the file. More than that scp command cannot be used to delete file. There's something wrong. Please post a log file.
Kami
Re: Cant delet file
Ah now i know whats the problem, if i connect with SCP then i get those errors but not when i connect with SFTP, ok thanx for help.
Re: Cant delet file
OK, but I would still like to solve the problem with SCP protocol. May I see the log file?
Kami
Re: Cant delet file
Ok I let the program make log file.
First I have copied a directory called Öffnungszeiten to a server – no error.
Then I tried to rename it – got this wildcard error. Then I tried to delete the file and got the same error. Here is the log:
. WinSCP Version 3.6.7 (Build 241) (OS 5.0.2195 Service Pack 3)
. Login time: Mittwoch, 18. August 2004 23:39:57
. Session name: zxmvd67@homepages.uni-tuebingen.de
. Host name: homepages.uni-tuebingen.de (Port: 22)
. User name: zxmvd67 (Password: Yes, Key file: No)
. Transfer Protocol: SFTP (SCP)
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: default, EOL: 0
. Local directory: default, Remote directory: home, Update: No, Cache: Yes
. Cache directory changes: Yes, Permanent: Yes
. Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. Looking up host "homepages.uni-tuebingen.de"
. Connecting to 134.2.2.67 port 22
. Server version: SSH-1.99-OpenSSH_3.4p1
. We claim version: SSH-2.0-WinSCP-release-3.6.7
. Host key fingerprint is:
. ssh-rsa 1024 0b:f8:7a:45:38:a7:c0:8d:4e:cb:0f:6d:01:65:f7:0e
! Using username "zxmvd67".
. Session password prompt (zxmvd67@homepages.uni-tuebingen.de's password: )
. Using stored password.
. Sent password
. Access granted
. Opened channel for session
. Started a shell/command
. Using SFTP protocol.
> Type: SSH_FXP_INIT, Size: 5, Number: -1
< Type: SSH_FXP_VERSION, Size: 5, Number: -1
. SFTP version 3 negotiated.
> Type: SSH_FXP_EXTENDED, Size: 38, Number: 200
< Type: SSH_FXP_STATUS, Size: 38, Number: 200
< Status/error code: 8
. Server does not recognise WinSCP.
. Getting real path for '.'
> Type: SSH_FXP_REALPATH, Size: 10, Number: 528
< Type: SSH_FXP_NAME, Size: 81, Number: 528
. Real path is '/info/www/data/stud/v6/zxmvd67'
. Listing directory "/info/www/data/stud/v6/zxmvd67".
> Type: SSH_FXP_OPENDIR, Size: 39, Number: 779
< Type: SSH_FXP_HANDLE, Size: 13, Number: 779
> Type: SSH_FXP_READDIR, Size: 13, Number: 1036
< Type: SSH_FXP_NAME, Size: 2981, Number: 1036
> Type: SSH_FXP_READDIR, Size: 13, Number: 1292
< Type: SSH_FXP_STATUS, Size: 28, Number: 1292
< Status/error code: 1
> Type: SSH_FXP_CLOSE, Size: 13, Number: 1540
< Type: SSH_FXP_STATUS, Size: 24, Number: 1540
< Status/error code: 0
. Startup conversation with host finished.
. Copying 1 files/directories to remote directory "/info/www/data/stud/v6/zxmvd67/"
.   PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No; FnCs: N; RIC: Yes; Resume: S (102400); CalcS: Yes; Mask: *.*
.   TM: M; ExclM:
.   AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. File: "E:\Studium\Öffnungszeiten"
. Trying to open directory "/info/www/data/stud/v6/zxmvd67/Öffnungszeiten/".
> Type: SSH_FXP_OPENDIR, Size: 54, Number: 1803
< Type: SSH_FXP_STATUS, Size: 29, Number: 1803
< Status/error code: 2, Message: 1803, Server: No such file, Language:
. Creating directory "/info/www/data/stud/v6/zxmvd67/Öffnungszeiten/".
. Canonifying: "/info/www/data/stud/v6/zxmvd67/Öffnungszeiten/"
. Getting real path for '/info/www/data/stud/v6/zxmvd67/Öffnungszeiten/'
> Type: SSH_FXP_REALPATH, Size: 55, Number: 2320
< Type: SSH_FXP_STATUS, Size: 29, Number: 2320
< Status/error code: 2, Message: 2320, Server: No such file, Language:
. Getting real path for '/info/www/data/stud/v6/zxmvd67/'
> Type: SSH_FXP_REALPATH, Size: 40, Number: 2576
< Type: SSH_FXP_NAME, Size: 81, Number: 2576
. Canonified: "/info/www/data/stud/v6/zxmvd67/Öffnungszeiten"
> Type: SSH_FXP_MKDIR, Size: 58, Number: 2062
< Type: SSH_FXP_STATUS, Size: 24, Number: 2062
> Type: SSH_FXP_SETSTAT, Size: 58, Number: 2825
< Type: SSH_FXP_STATUS, Size: 24, Number: 2825
. File: "E:\Studium\Öffnungszeiten\naldoLand Einzelansicht.htm"
. Copying "E:\Studium\Öffnungszeiten\naldoLand Einzelansicht.htm" to remote directory started.
. Ascii transfer mode selected.
. Opening remote file.
> Type: SSH_FXP_OPEN, Size: 98, Number: 3075
< Type: SSH_FXP_HANDLE, Size: 13, Number: 3075
> Type: SSH_FXP_WRITE, Size: 4106, Number: 3334
. 9 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> Type: SSH_FXP_CLOSE, Size: 13, Number: 4612
< Type: SSH_FXP_STATUS, Size: 24, Number: 4612
> Type: SSH_FXP_SETSTAT, Size: 94, Number: 4873
< Type: SSH_FXP_STATUS, Size: 24, Number: 4873
> Type: SSH_FXP_OPENDIR, Size: 39, Number: 5131
< Type: SSH_FXP_HANDLE, Size: 13, Number: 5131
> Type: SSH_FXP_READDIR, Size: 13, Number: 5388
< Type: SSH_FXP_NAME, Size: 3105, Number: 5388
> Type: SSH_FXP_READDIR, Size: 13, Number: 5644
< Type: SSH_FXP_STATUS, Size: 28, Number: 5644
> Type: SSH_FXP_CLOSE, Size: 13, Number: 5892
< Type: SSH_FXP_STATUS, Size: 24, Number: 5892
. Renaming file "Öffnungszeiten" to "Offnungszeiten".
> Type: SSH_FXP_RENAME, Size: 103, Number: 6162
< Type: SSH_FXP_STATUS, Size: 24, Number: 6162
> Type: SSH_FXP_OPENDIR, Size: 39, Number: 6411
< Type: SSH_FXP_HANDLE, Size: 13, Number: 6411
> Type: SSH_FXP_READDIR, Size: 13, Number: 6668
< Type: SSH_FXP_NAME, Size: 3105, Number: 6668
> Type: SSH_FXP_READDIR, Size: 13, Number: 6924
< Type: SSH_FXP_STATUS, Size: 28, Number: 6924
> Type: SSH_FXP_CLOSE, Size: 13, Number: 7172
< Type: SSH_FXP_STATUS, Size: 24, Number: 7172
. Deleting file "Offnungszeiten".
. Listing directory "/info/www/data/stud/v6/zxmvd67/Offnungszeiten".
> Type: SSH_FXP_OPENDIR, Size: 54, Number: 7435
< Type: SSH_FXP_HANDLE, Size: 13, Number: 7435
> Type: SSH_FXP_READDIR, Size: 13, Number: 7692
< Type: SSH_FXP_NAME, Size: 357, Number: 7692
> Type: SSH_FXP_READDIR, Size: 13, Number: 7948
< Type: SSH_FXP_STATUS, Size: 28, Number: 7948
> Type: SSH_FXP_CLOSE, Size: 13, Number: 8196
< Type: SSH_FXP_STATUS, Size: 24, Number: 8196
. Deleting file "Offnungszeiten/naldoLand Einzelansicht.htm".
> Type: SSH_FXP_REMOVE, Size: 82, Number: 8461
< Type: SSH_FXP_STATUS, Size: 24, Number: 8461
> Type: SSH_FXP_RMDIR, Size: 54, Number: 8719
< Type: SSH_FXP_STATUS, Size: 24, Number: 8719
> Type: SSH_FXP_OPENDIR, Size: 39, Number: 8971
< Type: SSH_FXP_HANDLE, Size: 13, Number: 8971
> Type: SSH_FXP_READDIR, Size: 13, Number: 9228
< Type: SSH_FXP_NAME, Size: 2981, Number: 9228
> Type: SSH_FXP_READDIR, Size: 13, Number: 9484
< Type: SSH_FXP_STATUS, Size: 28, Number: 9484
> Type: SSH_FXP_CLOSE, Size: 13, Number: 9732
< Type: SSH_FXP_STATUS, Size: 24, Number: 9732
. Closing connection.
. Login time: Mittwoch, 18. August 2004 23:42:12
. Transfer Protocol: SCP
. Proxy: none
. Sent password
. Access granted
. Using SCP protocol.
. Skipping host startup message (if any).
> echo "WinSCP: this is end-of-file:0"
< WinSCP: this is end-of-file:0
. Detecting variable containing return code of last command.
. Trying "$status".
> echo "$status" ; echo "WinSCP: this is end-of-file:0"
< 0
. Return code variable "$status" selected.
. Clearing all aliases.
> unalias "echo" ; echo "WinSCP: this is end-of-file:$status"
> unalias "pwd" ; echo "WinSCP: this is end-of-file:$status"
> unalias "cd" ; echo "WinSCP: this is end-of-file:$status"
> unalias "ls" ; echo "WinSCP: this is end-of-file:$status"
> unalias "groups" ; echo "WinSCP: this is end-of-file:$status"
> unalias "scp" ; echo "WinSCP: this is end-of-file:$status"
> unalias "rm" ; echo "WinSCP: this is end-of-file:$status"
> unalias "mv" ; echo "WinSCP: this is end-of-file:$status"
> unalias "mkdir" ; echo "WinSCP: this is end-of-file:$status"
> unalias "chmod" ; echo "WinSCP: this is end-of-file:$status"
> unalias "chgrp" ; echo "WinSCP: this is end-of-file:$status"
> unalias "chown" ; echo "WinSCP: this is end-of-file:$status"
> unalias "unset" ; echo "WinSCP: this is end-of-file:$status"
> unalias "unalias" ; echo "WinSCP: this is end-of-file:$status"
> unalias "alias" ; echo "WinSCP: this is end-of-file:$status"
> unalias "ln" ; echo "WinSCP: this is end-of-file:$status"
> unalias "%s" ; echo "WinSCP: this is end-of-file:$status"
. Clearing national user variables.
> unset "LANG" ; echo "WinSCP: this is end-of-file:$status"
> unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$status"
> unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$status"
> unset "LC_COLLATE" ; echo "WinSCP: this is end-of-file:$status"
> unset "LC_MONETARY" ; echo "WinSCP: this is end-of-file:$status"
> unset "LC_NUMERIC" ; echo "WinSCP: this is end-of-file:$status"
> unset "LC_TIME" ; echo "WinSCP: this is end-of-file:$status"
> unset "LC_MESSAGES" ; echo "WinSCP: this is end-of-file:$status"
> unset "LC_ALL" ; echo "WinSCP: this is end-of-file:$status"
> unset "HUMAN_BLOCKS" ; echo "WinSCP: this is end-of-file:$status"
. Looking up groups and users.
> groups ; echo "WinSCP: this is end-of-file:$status"
< homeinfo
. Following groups found:
.   homeinfo
. No users found.
> pwd ; echo "WinSCP: this is end-of-file:$status"
< /info/www/data/stud/v6/zxmvd67
. Listing current directory.
> ls -la ; echo "WinSCP: this is end-of-file:$status"
< total 176
< drwxr-x---    7 zxmvd67  httpd        4096 Aug 18 23:36 .
< drwxr-x---    5 root     homeinfo     4096 Apr 30 13:53 ..
< -rw-r--r--    1 zxmvd67  homeinfo      356 May 26 23:45 archiv.html
< -rw-r--r--    1 zxmvd67  homeinfo    58138 May 29 21:27 bild.jpg
< -rw-r--r--    1 zxmvd67  homeinfo     4781 May  1 00:28 bild2.jpg
< drwxr-xr-x    7 zxmvd67  homeinfo     4096 Jun  3 09:28 bilder
< -rw-r--r--    1 zxmvd67  homeinfo     1744 Jun 13 00:45 bilder.html
< drwxr-xr-x    3 zxmvd67  homeinfo     4096 May 28 16:34 cgi-bin
< drwxr-xr-x    3 zxmvd67  homeinfo     4096 May 28 16:34 downloads
< -rw-r--r--    1 zxmvd67  homeinfo     1793 May 29 21:49 downloads.html
< -rw-r--r--    1 zxmvd67  homeinfo     1951 May 29 21:31 email.jpg
< -rw-r--r--    1 zxmvd67  homeinfo      468 Jul 16 22:37 head.html
< -rw-r--r--    1 zxmvd67  homeinfo     1181 Jun 13 00:02 home.html
< -rw-r--r--    1 zxmvd67  homeinfo     1013 Jun  3 21:27 index.html
< -rw-r--r--    1 zxmvd67  homeinfo     4562 Jul 25 20:57 klausuren.html
< -rw-r--r--    1 zxmvd67  homeinfo      906 Jun  3 21:33 kontakt.html
< -rw-r--r--    1 zxmvd67  homeinfo     2651 Jun  9 16:50 links.html
< -rw-r--r--    1 zxmvd67  homeinfo      171 May 26 23:41 logo.html
< -rw-r--r--    1 zxmvd67  homeinfo     2794 Jul 16 21:53 menu.html
< -rw-r--r--    1 zxmvd67  homeinfo     4614 Jul 16 22:36 nachrichten.html
< drwxr-xr-x    2 zxmvd67  homeinfo     4096 May 28 16:34 spass
< -rw-r--r--    1 zxmvd67  homeinfo     1947 Jul 25 21:05 spass.html
< -rw-r--r--    1 zxmvd67  homeinfo      397 Apr 29 00:34 statistik.html
< drwxr-xr-x    2 zxmvd67  homeinfo     4096 May 28 16:34 uber
< -rw-r--r--    1 zxmvd67  homeinfo     2211 Jul 16 21:54 uber.html
< -rw-r--r--    1 zxmvd67  homeinfo     1100 Jul 25 20:55 wissen.html
.   TM: M; ExclM:
> echo "WinSCP: this is begin-of-file" ; scp -r  -d -t "/info/www/data/stud/v6/zxmvd67" ; echo "WinSCP: this is end-of-file:$status"
< WinSCP: this is begin-of-file
. SCP remote side confirmation (0)
. Entering directory "E:\Studium\Öffnungszeiten".
> D0755 0 Öffnungszeiten
> T1091706012 0 1092865270 0
> C0644 18108 naldoLand Einzelansicht.htm
. Sending ASCII data (18108d bytes)
. Sending NULL.
. Copying "E:\Studium\Öffnungszeiten\naldoLand Einzelansicht.htm" to remote directory finished.
. Leaving directory "E:\Studium\Öffnungszeiten".
> E
. Copying "E:\Studium\Öffnungszeiten" to remote directory finished.
> E
< total 180
< drwxr-x---    8 zxmvd67  httpd        4096 Aug 18 23:37 .
< drwxr-xr-x    2 zxmvd67  homeinfo     4096 Aug 18 23:37 Öffnungszeiten
> mv -f "Öffnungszeiten" "Offnungszeiten" ; echo "WinSCP: this is end-of-file:$status"
! invalid characters in scp command!
! here:Öffnungszeiten" "Offnungszeiten"
! try using a wildcard to match this file/directory
< WinSCP: this is end-of-file:-1
. Asking user:
. Fehler beim Umbenennen der Datei 'Öffnungszeiten' nach 'Offnungszeiten'. ("Befehl 'mv -f ""Öffnungszeiten"" ""Offnungszeiten""'
. fehlgeschlagen mit Beendigungscode -1 und Fehlernachricht
. invalid characters in scp command!
. here:Öffnungszeiten"" ""Offnungszeiten""
. try using a wildcard to match this file/directory.")
. Deleting file "Öffnungszeiten".
> rm -f -r "Öffnungszeiten" ; echo "WinSCP: this is end-of-file:$status"
. Asking user:
. Fehler beim Löschen  der Datei 'Öffnungszeiten'. ("Befehl 'rm -f -r ""Öffnungszeiten""'
. Asking user:
< total 180
Kami
Re: Cant delet file
Ah sorry first part of the log is SFTP connection, the second part is SCP wich isnt working correct.
Re: Cant delet file
It seems like some strange limitation of your system. I have no idea how to help you, but if SFTP works, than use it :-)
Kami
Re: Cant delet file
Well fact is, if i connect with my uni-account then i get the same errors too. In my UNI, WinSCP is installed as a default application to connect the web storage, because they don't support FTP anymore. Now i checked the support site and they write if I want to use öäüß then i should select SFTP. Why I didn't read it before.
:evil: :D
