WinSCP.com opens wrong site, ignoring config & script
rodfun
Using WinSCP Version 5.6.5 RC (Build 4982)
I can use WinSCP.com to connect to my host successfully at the command line.
But when I run a batch file, it trys to connect to an old FTP site that is no longer configured in WinSCP. I deleted it.
It seems to ignore my batch file commands: "C:\Program Files (x86)\WinSCP\winSCP.com" /script=HHSiteUpdate.txt
It attempts to connect to a site not referred to in that txt file, as I said the old site I was using.
I checked WinSCP.ini and it only has the correct site listed.
I checked for other copies of WinSCP.ini.
I made sure it loads the WinSCP.ini from the C:\Program Files (x86)\WinSCP
It doesn't matter if I use /ini= even with a unique ini file name.
Can't figure it out.
Any help or advice appreciated.
Thanks.
Re: WinSCP.com opens wrong site, ignoring config & script
rodfun
WinSCP.com script opens wrong host in batch mode
Thanks, Here is the log.
It ignores the script HHSiteBackUp.txt which is in the current working directory. If I enter the script line by line it works fine. But its selecting this old FTP site IP 162..., and I can't see where that's coming from.
  • temp.log (2.33 KB, Private file)
rodfun
Never mind. I figured it out from the log.
Wrong script called. I had two with similar names.
Sorry.
