winscp.exe "mySession" /open "path" will open dir or file
t603
Prague
Good afternoon,
I am testing WinSCP 5.6.5 RC, the new feature /edit. I have two feature requests:
Would it be possible to add /open command, which will in case of path of type :
a) directory (start WinSCP, if not started... and) open the directory,
b) file (start WinSCP, if not started... and) open the file in EXTERNAL editor.
Thank You, Stepan
Re: winscp.exe "mySession" /open "path" will open dir or file
Use winscp.exe sftp://example.com/directory/to/open/
The trailing slash is important.
See https://winscp.net/eng/docs/commandline#session
That's bit problematic as it requires WinSCP to run in the background watching for the edited file. But how? Hidden completely? Just a tray icon? Not sure about that.
