Regular crashes
Marcus P.
Regular crashes
Since one of the last updates, I have regular crashes in WinSCP.
In most cases it crashes under the following circumstances:
1.) Log into a ftp sever.
2.) Choose a target directory and start an upload. (queued background upload)
3.) While the upload is running, switch ftp server directories and create a new folder and subfolder.
4.) When I try to open the newly created subfolder, in some cases a flashlight animation appears and in most cases the client crashes in that case.
I've added the crash log from windows event manager. Let me know if you need more info.
Name der fehlerhaften Anwendung: WinSCP.exe, Version: 5.6.5.4982, Zeitstempel: 0x00000000
Name des fehlerhaften Moduls: WinSCP.exe, Version: 5.6.5.4982, Zeitstempel: 0x00000000
Ausnahmecode: 0xc0000005
Fehleroffset: 0x0038d25b
ID des fehlerhaften Prozesses: 0x16fc
Startzeit der fehlerhaften Anwendung: 0x01d0355b9398dde5
Pfad der fehlerhaften Anwendung: C:\Program Files (x86)\WinSCP\WinSCP.exe
Pfad des fehlerhaften Moduls: C:\Program Files (x86)\WinSCP\WinSCP.exe
Berichtskennung: 777f86fc-a150-11e4-ba1f-bcaec5706c14
Kind Regards,
Marcus
Re: Regular crashes
Marcus Pukropski
Germany
Re: Regular crashes
https://winscp.net/tracker/1272
Hi Martin,
Looks good so far. No matter how fast I change directories, create new ones or just navigate in the remote window, I couldn't trigger the issue any longer.
Many thanks for the quick help and the fix!
Kind Regards,
Marcus
Re: Regular crashes
Thanks for your feedback.
cpergantis
now crashing my windows 10 while in sleep mode
I have just changed my storage method from registry to ini file to see if this prevents further win 10 blue screens. Will return in a few weeks to let you know.
