Synchronize file type in order - help needed
Hi!
I'm synchronizing directories and all works fine but I need help.
I would like to download (synchronize) first all files that are NOT .xml and then download remaining .xml files.
Anybody could help me. Please.
m.
m.
Try { # Connect $session.Open($sessionOptions) $localPath = "E:\test\import" $remotePath = "/" # Synchronize files to local directory, collect results $synchronizationResult = $session.SynchronizeDirectories( [WinSCP.SynchronizationMode]::Local, $localPath, $remotePath, $False, $False, [WinSCP.SynchronizationCriteria]::Time, $transferOptions) foreach ($download in $synchronizationResult.Downloads) { # Success or error? if ($download.Error -eq $Null) { Write-Host ("Download of {0} succeeded, removing from source" -f $download.FileName) # Download succeeded, remove file from source $removalResult = $session.RemoveFiles($session.EscapeFileMask($download.FileName)) if ($removalResult.IsSuccess) { Write-Host ("Removing of file {0} succeeded" -f $download.FileName) } else { Write-Host ("Removing of file {0} failed" -f $download.FileName) } } else { Write-Host ("Download of {0} failed: {1}" -f $download.FileName, $download.Error.Message) } } } finally { # Disconnect, clean up $session.Dispose() } exit 0 } catch [Exception] { Write-Host $_.Exception.Message exit 1 }
