Appending to logs
rsawney
Appending to logs
It does not seem to be possible to append to xml logs. I can see why!
My problem would be solved if I could control what goes into the non xml log - is there a way of controlling what is output - I am using a command line call.
Re: Appending to logs
You cannot control what goes to session log. Only XML log is intended for any kind of processing. Why do you need to append them?
