Keep remote directory up to date
guest:Walter
This feature (good one!) maxes out at 62 (?64) directories, any chance this will be 1024 2048 or larger?
Would be appreciated !
wkempees@hotmail.com
Re: Keep remote directory up to date
Windows limits number of directories being watched simultaneously to 64 (WinSCP uses 2 for its internal purposes, hence the 62 limit).
Of course, if I try I may find some solution. But I won't unless people ask for it. One vote is not good enough, sorry :-( So let's wait :-)
No worries, product works great.
Wishes are wishes, not demands.
I do things on a lower directory level now as a workaround.
Thanks for reply, keep it up!
Nobody
I'm sure there are many votes but since your polling system is worse than the one used by the Florida Electoral Process I'm sure you will miss many such votes. :)
