put command not working all the time
ncklly
Idaho
I searched for help to this in forum, but did not see this exact problem so pardon me if I missed it. When I run this file from a dos prompt it works just fine.
c:\WinSCP.com /script=myFile.txt
here is what is in myfile.txt
option echo off
option batch abort
open sftp://101-05:??????@sftp.????????.com
put -nopermissions -resumesupport=off -nopreservetime \folder\folder\408921_20150107154000.txt
close
If an unattended process runs it like a task schedule or batch file or a C++ program shelling out to a dos prompt or I have tried just about everything it never really does or 'put's anything, I can see it connect, but the put just zooms right passed and does nothing, but if I run it from a dos prompt as above I can see it do everything. It is like my put is not working.
Any ideas? Thanks so much
WinSCP V5.5.1(build 3970)
Windows 7
Re: put command not working all the time
Please read FAQ:
https://winscp.net/eng/docs/faq_scheduler
If that does not help, come back and attach a session log file.
The log really helped, thank you, but here is the problem I am having.
. 2015-01-19 02:28:41.927   TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; InclM:
. 2015-01-19 02:28:41.927   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
* 2015-01-19 02:28:41.947 (EOSError) System Error.  Code: 2.
* 2015-01-19 02:28:41.947 The system cannot find the file specified
. 2015-01-19 02:28:41.947 Asking user:
. 2015-01-19 02:28:41.947 File or folder '\Nick001\File\408921_20150119154000.txt' does not exist. ("System Error.  Code: 2.
. 2015-01-19 02:28:41.947 The system cannot find the file specified")
< 2015-01-19 02:28:41.947 Script: File or folder '\Nick001\File\408921_20150119154000.txt' does not exist.
< 2015-01-19 02:28:41.947 Script: System Error.  Code: 2.
So I must have this line wrong.
put -nopermissions -resumesupport=off -nopreservetime \Nick001\File\408921_20150119154000.txt
Do I need the drive letter indication like for example
put -nopermissions -resumesupport=off -nopreservetime d:\Nick001\File\408921_20150119154000.txt
Thank you
Depends on what your local working directory is. I could tell that from a log, had you attached it.
Anyway, using an absolute path can only improve this, so it's worth trying.
