Where can I find the directory and file listings on my local machine?
I'm trying to upload a file to a remote server from my desktop machine using WinSCP. I can't find where my listing of local PC files are.
Can anyone tell me how to upload files from desktop to server? I seem to only be able to download from server to home PC (and find only remote and not local files).
Thanks anyone.
Re: Where can I find the directory and file listings on my local machine?
I may not understand what your problem is. However here are some suggestions:
You may drag files from windows explorer (or even your desktop) to WinSCP to upload them. If you want to use keyboard, make sure you are using Norton Commander-style interface. See Preferences window.
