Problem connecting
akratzert
Problem connecting
Hi there, I am receiving this message when trying to connect to a server via SFTP:
Unable to use key file "?C:\Services\PrivateSSHKeyNP.ppk" (unable to open file) Using username "myuser". Authentication failed.
Protocol = Protocol.Sftp,
HostName = "someserver.com",
PortNumber = 22,
UserName = "myuser",
SshHostKeyFingerprint = <host fingerprint>,
SshPrivateKeyPath = "C:\Services\PrivateSSHKeyNP.ppk"
The key file was made with PuttyGen and I can use your client application and a different FTP client to connect using this Private Key file.
The Private Key file has no password.
What am I doing wrong?
Re: Problem connecting
Your string syntax is wrong. You have to escape the backslashes. Either use "C:\\Services\\PrivateSSHKeyNP.ppk" or @"C:\Services\PrivateSSHKeyNP.ppk".
If this does not help, please attach a full session log file showing the problem (using the latest version of WinSCP).
