can't connect with putty ppk
random512
Hello, I installed WinSCP. As part of the installation process, it asked to import my putty configuration and I confirmed. However, if I try to connect through WinSCP with a saved session settings file from Putty then WinSCP returns the following error:
"Disconnected: No supported authentication methods available (server sent: publickey)"
Any idea what might be causing this error and how to fix?
Re: can't connect with putty ppk
About this issue, I know how to reproduce this, at least in the portable versions I use (both WinSCP and Putty from PortableApps.com).
Just create in Putty a profile with EXACTLY the same name as the one you are using with WinSCP, then start putty from the WinSCP session and that's it, errors in supported authentication methods.
If you just remove (or rename in a different way) that Putty profile, launching it from WinSCP works without issues.
Do you get the error in PuTTY or WinSCP?
It's actually by design.
If there's a PuTTY session with the same name as the current WinSCP session, WinSCP opens that PuTTY session. It won't export its settings to PuTTY.
If the PuTTY session is not configured correctly, it just won't work.
See https://winscp.net/eng/docs/integration_putty#session_configuration
Thanks for pointing this out, anyway, the Putty sessions are configured correctly...
Putty (launched by itself) works with that session
WinSCP works with it's session with the same name
WinSCP opening a Putty terminal with the common-named session gives the error
now that I think of it, I wonder if the issue could be caused by the path referenced for the ssh key file...
While Putty needs ".\Data\key.ppk", WinSCP uses "..\..\Data\key.ppk", so both programs are pointing at the same file with a different path
Post PuTTY event logs both for the failing session started from WinSCP and the working session started from PuTTY itself.
It's indeed a path issue (while using relative paths), also the "putty.log" was written in two different paths:
Launched from Putty:
.\PortableApps\PuTTYPortable\putty.log
(I removed some info from the logs, like username/domain and IP)
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2016.05.27 17:12:16 =~=~=~=~=~=~=~=~=~=~=~=
Using username "XXXX".
Authenticating with public key "rsa-key-XXXXXXXX"
Last login: Fri May 27 17:05:52 2016 from XX.XX.XXX.XXX
]0;XXXX@XXXX:~[?1034h[XXXX@XXXX ~]# exit
logout
Launched from WinSCP:
.\PortableApps\WinSCPPortable\App\winscp\putty.log
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2016.05.27 17:13:45 =~=~=~=~=~=~=~=~=~=~=~=
Unable to use key file ".\Data\key.ppk" (unable to open file)
Maybe a possible solution could be to make WinSCP change the working directory to the one where Putty is installed, before launching it ?
Anyway, thank you for the interest and all the work with WinSCP, could be cool to have all the sessions with the same name everywhere, but it's not at all a top priority thing, it's easy to workarond this issue, I just have to remember to not name putty and winscp session the same ;)
This request has been added to the tracker:
https://winscp.net/tracker/1430
Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
