Not recognized listing format from toolbox ls command
jkk88
When try to connect to android cyanogenmod builtin ssh server (version 11 but probably all) by using SCP protocol I get only
Unexpected directory listing line 'drwxr-xr-x root root 1970-02-03 01:41 acct'.
Workaround is to set "busybox ls -la" in directory listing command advanced session configuration.
Here is example for format used by ls -la issued in root directory:
root@C1905:/ # ls -l `which ls`
lrwxrwxrwx root     root              1970-01-23 22:09 ls -> toolbox
root@C1905:/ # ls -la
-rw------- root     root            2 2014-12-28 15:18 boot.chk
-rw-r--r-- root     root          102 1970-02-03 01:41 boot.txt
drwxrwx--x system   cache             2014-12-17 23:58 cache
-rwxr-x--- root     root       284704 1970-02-03 01:41 charger
dr-x------ root     root              1970-02-03 01:41 config
lrwxrwxrwx root     root              1970-02-03 01:41 d -> /sys/kernel/debug
drwxrwx--x system   system            2014-12-28 15:16 data
-rw-r--r-- root     root          136 1970-02-03 01:41 default.prop
drwxr-xr-x root     root              2014-12-28 15:18 dev
lrwxrwxrwx root     root              1970-02-03 01:41 etc -> /system/etc
lrwxrwxrwx root     root              1970-02-03 01:41 ext_card -> /storage/sdcard1
-rw-r--r-- root     root        11071 1970-02-03 01:41 file_contexts
dr-xr-x--- system   system            1970-01-01 01:00 firmware
-rw-r----- root     root         1208 1970-02-03 01:41 fstab.qcom
-rwxr-x--- root     root       187840 1970-02-03 01:41 init
-rwxr-x--- root     root         1822 1970-02-03 01:41 init.class_main.sh
-rwxr-x--- root     root         6622 1970-02-03 01:41 init.cm.rc
-rwxr-x--- root     root          992 1970-02-03 01:41 init.environ.rc
-rwxr-x--- root     root        20490 1970-02-03 01:41 init.qcom.rc
-rwxr-x--- root     root         5735 1970-02-03 01:41 init.qcom.usb.rc
-rwxr-x--- root     root        22030 1970-02-03 01:41 init.rc
-rwxr-x--- root     root          341 1970-02-03 01:41 init.recovery.qcom.rc
-rwxr-x--- root     root          301 1970-02-03 01:41 init.superuser.rc
-rwxr-x--- root     root        12056 1970-02-03 01:41 init.target.rc
-rwxr-x--- root     root         1795 1970-02-03 01:41 init.trace.rc
-rwxr-x--- root     root         3915 1970-02-03 01:41 init.usb.rc
-rw-r--r-- root     root         7660 1970-01-01 01:00 logo.rle
drwxr-xr-x root     root              1970-01-01 01:00 lta-label
drwxrwxr-x root     system            1970-02-03 01:41 mnt
drwxrwx--x system   system            2009-01-02 14:00 persist
dr-xr-xr-x root     root              1970-01-01 01:00 proc
-rw-r--r-- root     root         2161 1970-02-03 01:41 property_contexts
drwxr-xr-x root     root              1970-02-03 01:41 res
drwx------ root     root              2014-12-17 22:13 root
drwxr-x--- root     root              1970-02-03 01:41 sbin
lrwxrwxrwx root     root              1970-02-03 01:41 sdcard -> /storage/emulated/legacy
-rw-r--r-- root     root          660 1970-02-03 01:41 seapp_contexts
-rw-r--r-- root     root        96188 1970-02-03 01:41 sepolicy
drwxr-x--x root     sdcard_r          1970-02-03 01:41 storage
dr-xr-xr-x root     root              1970-02-03 01:41 sys
drwxr-xr-x root     root              2014-12-28 15:18 system
lrwxrwxrwx root     root              1970-02-03 01:41 tombstones -> /data/tombstones
-rw-r--r-- root     root         8196 1970-02-03 01:41 ueventd.qcom.rc
-rw-r--r-- root     root         7275 1970-02-03 01:41 ueventd.rc
lrwxrwxrwx root     root              1970-02-03 01:41 usbdisk -> /storage/usbdisk
lrwxrwxrwx root     root              1970-02-03 01:41 vendor -> /system/vendor
root@C1905:/ #
Please add this ls format to winscp.
Test version WinSCP, Version 5.5.6 (Build 4746)
Re: Not recognized listing format from toolbox ls command
The format is way too different to any that WinSCP supports. Isn't there SFTP support on cyanogenmod?
