Resuming from Broken Connections uses default remote folder
Georg
WinSCP 5.5.6 (Build 4746), Windows 7 Ultimate 64 bit
I'm using the commander GUI to select many files in the directory A (active) on my ftp server to copy them to my local HDD. When my server reboots while copying thes files WinSCP reconnects to the directory D (default remote folder stored in the preferences) and fails to resume copying when A is not equal D.
After that the directory listing still shows the folder A and the files that are to be copied are still selected. But when I press F5 and answer Yes the files are fetched from folder D -> Error.
Re: Resuming from Broken Connections uses default remote folder
Georg
After reconnecting to the server the interrupted transfer of the current file is resumed (from directory A). The following file in the list of files to be transferred is fetched from directory D. This gives the error.
  • 20141223231801.log (198.03 KB, Private file)
Thanks for the log. While I can see the problem, I cannot reproduce it.
Thanks for the log. And sorry for later answer, I have been on vacation.
https://winscp.net/tracker/1268
I'm sending you an email with a dev version of WinSCP to address you have used to register on this forum.
Resent. Are you aware that you registered with a strange email address (winscp-specific), possibly even non-existing one?
Georg
It looks like this bug has been fixed. I copied 3 files, rebooted my server during the transfer of the 1st file and all files were finally copied. Thank you.
