rsa fingerprint is saved - call not successful
ThLeh
i'm confused. We have 5 pc which makes a sftp connection to a server. Now the ip of the server has changed and the connection with 4 pc is successful after storing the rsa fingerprint on the system.
One system makes trouble.
- Connected with the gui and saved the new fingerprint.
- CMD call of C:\Program Files (x86)\WinSCP\winscp.com /console /command "option batch abort" "option confirm off" "option transfer binary" "open sftp://user:pass@serverip" is successful
- when winscp is called out of another application (same string) i get the error that the fingerprint is not saved.
- copied registry key from one running system, same error
- checked context, application is running on the same username like the gui.
- uninstalled winscp, installed same version like on the other systems, installed newest version, no change.
I don't have any more ideas what we can check anymore.
Can anyone help me?
Thanks ThLeh
Re: rsa fingerprint is saved - call not successful
Please attach a full log file both from successful GUI and failing script sessions (using the latest version of WinSCP).
ThLeh
Hello Martin,
many thanks for your debugging. The calling program was really wrong. It works now!
You've saved my holidays :D
Best regards,
Thorsten
