upload only .zip files that are older than 2 days
sumation
hi All,
how can i do a script in WinSCP that uploads .zip files that are more than 2 days old
thanks
Re: upload only .zip files that are older than 2 days
This is what i did not sure if correct because it does notwork.
option batch abort
put *.zip<1D C:\
It's difficult to help you if you do not tell us "what does not work".
Anyway, the script lacks open command.
