Folder Name and File name issues (automation script)
lswalker85
Hey, I run an automation script across multiple FTP Sites and have had no issues until one weekend one of the three shows [m:c79863df48]/'s before and after each folder as well as full path for folders and files.
This is causing issues with downloading files as the path cannot be found. When I use the Copy to Clipboard (Include Path) I get [m]/EDI/Emdeon/2014/NewFiles//EDI/Emdeon/2014/NewFiles/m837.20141208.POD4.05143[/m:c79863df48]. The actual path is /EDI/Emdeon/2014/NewFiles/m837.20141208.POD4.05143.
I've checked with the FTP Server and they say it looks fine from their side. FileZilla also shows no /folder/ names.
Any idea how to get WinSCP to recognize file and folder names as the other sessions do?
Thanks for the help.
Re: Folder Name and File name issues (automation script)
lswalker85
WinSCP version: 5.5.6 (Build 4767)
Session Log, my comments added as // ME - :
. 2014-12-12 11:05:33.657 --------------------------------------------------------------------------
. 2014-12-12 11:05:33.657 WinSCP Version 5.5.6 (Build 4746) (OS 6.1.7601 Service Pack 1 - Windows 7 Enterprise)
. 2014-12-12 11:05:33.657 Configuration: C:\Program Files (x86)\WinSCP\WinSCP.ini
. 2014-12-12 11:05:33.657 Local account: HOME\ME
. 2014-12-12 11:05:33.657 Working directory: C:\Windows\system32
. 2014-12-12 11:05:33.657 Process ID: 3236
. 2014-12-12 11:05:33.657 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe" "SPH" /UploadIfAny /JumpList
. 2014-12-12 11:05:33.667 Time zone: Current: GMT-8, Standard: GMT-8 (Pacific Standard Time), DST: GMT-7 (Pacific Daylight Time), DST Start: 3/9/2014, DST End: 11/2/2014
. 2014-12-12 11:05:33.667 Login time: Friday, December 12, 2014 11:05:33 AM
. 2014-12-12 11:05:33.667 --------------------------------------------------------------------------
// ME - Connection part removed.
. 2014-12-12 11:05:35.395 --------------------------------------------------------------------------
. 2014-12-12 11:05:35.395 Using SFTP protocol.
. 2014-12-12 11:05:35.395 Doing startup conversation with host.
> 2014-12-12 11:05:35.445 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2014-12-12 11:05:35.515 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2014-12-12 11:05:35.515 SFTP version 3 negotiated.
. 2014-12-12 11:05:35.525 We believe the server has signed timestamps bug
. 2014-12-12 11:05:35.525 We will use UTF-8 strings when appropriate
// ME - /EDI/Emdeon/2014 is the remembered last used directory.
. 2014-12-12 11:05:35.545 Changing directory to "/EDI/Emdeon/2014".
. 2014-12-12 11:05:35.545 Getting real path for '/EDI/Emdeon/2014'
> 2014-12-12 11:05:35.545 Type: SSH_FXP_REALPATH, Size: 25, Number: 16
< 2014-12-12 11:05:35.615 Type: SSH_FXP_NAME, Size: 55, Number: 16
. 2014-12-12 11:05:35.615 Real path is '/EDI/Emdeon/2014'
. 2014-12-12 11:05:35.615 Trying to open directory "/EDI/Emdeon/2014".
> 2014-12-12 11:05:35.615 Type: SSH_FXP_LSTAT, Size: 25, Number: 263
< 2014-12-12 11:05:35.685 Type: SSH_FXP_ATTRS, Size: 21, Number: 263
. 2014-12-12 11:05:35.685 Getting current directory name.
. 2014-12-12 11:05:35.845 Listing directory "/EDI/Emdeon/2014".
> 2014-12-12 11:05:35.845 Type: SSH_FXP_OPENDIR, Size: 25, Number: 523
< 2014-12-12 11:05:35.915 Type: SSH_FXP_HANDLE, Size: 10, Number: 523
> 2014-12-12 11:05:35.915 Type: SSH_FXP_READDIR, Size: 10, Number: 780
< 2014-12-12 11:05:35.995 Type: SSH_FXP_NAME, Size: 233, Number: 780
> 2014-12-12 11:05:35.995 Type: SSH_FXP_READDIR, Size: 10, Number: 1036
< 2014-12-12 11:05:36.065 Type: SSH_FXP_STATUS, Size: 22, Number: 1036
< 2014-12-12 11:05:36.065 Status code: 1
> 2014-12-12 11:05:36.065 Type: SSH_FXP_CLOSE, Size: 10, Number: 1284
. 2014-12-12 11:05:36.065 /EDI/Emdeon/2014/Archive/;d;0;2014-12-11T22:24:34.000Z;"user" [0];"group" [0];rwxrw-rw-;1
. 2014-12-12 11:05:36.065 /EDI/Emdeon/2014/NewFiles/;d;0;2014-12-12T14:05:11.000Z;"user" [0];"group" [0];rwxrw-rw-;1
. 2014-12-12 11:05:36.145 Startup conversation with host finished.
// ME - Tried changing to a 'blank' directory in the directory tree pane.
. 2014-12-12 11:05:41.834 Changing directory to "/EDI/Emdeon/2014//EDI/Emdeon/2014/Archive/".
. 2014-12-12 11:05:41.834 Getting real path for '/EDI/Emdeon/2014//EDI/Emdeon/2014/Archive/'
> 2014-12-12 11:05:41.834 Type: SSH_FXP_REALPATH, Size: 51, Number: 1552
< 2014-12-12 11:05:41.844 Type: SSH_FXP_STATUS, Size: 21, Number: 1284
. 2014-12-12 11:05:41.844 Discarding reserved response
< 2014-12-12 11:05:41.914 Type: SSH_FXP_STATUS, Size: 33, Number: 1552
< 2014-12-12 11:05:41.914 Status code: 2, Message: 1552, Server: File not found, Language: en
* 2014-12-12 11:05:41.914 (ECommand) Error changing directory to '/EDI/Emdeon/2014//EDI/Emdeon/2014/Archive/'.
* 2014-12-12 11:05:41.914 Cannot get real path for '/EDI/Emdeon/2014//EDI/Emdeon/2014/Archive/'.
* 2014-12-12 11:05:41.914 No such file or directory.
* 2014-12-12 11:05:41.914 Error code: 2
* 2014-12-12 11:05:41.914 Error message from server (en): File not found
// ME - Tried changing to the other 'blank' directory in the directory tree pane.
. 2014-12-12 11:05:44.147 Changing directory to "/EDI/Emdeon/2014//EDI/Emdeon/2014/NewFiles/".
. 2014-12-12 11:05:44.147 Getting real path for '/EDI/Emdeon/2014//EDI/Emdeon/2014/NewFiles/'
> 2014-12-12 11:05:44.147 Type: SSH_FXP_REALPATH, Size: 52, Number: 1808
< 2014-12-12 11:05:44.227 Type: SSH_FXP_STATUS, Size: 33, Number: 1808
< 2014-12-12 11:05:44.227 Status code: 2, Message: 1808, Server: File not found, Language: en
* 2014-12-12 11:05:44.227 (ECommand) Error changing directory to '/EDI/Emdeon/2014//EDI/Emdeon/2014/NewFiles/'.
* 2014-12-12 11:05:44.227 Cannot get real path for '/EDI/Emdeon/2014//EDI/Emdeon/2014/NewFiles/'.
* 2014-12-12 11:05:44.227 No such file or directory.
* 2014-12-12 11:05:44.227 Error code: 2
* 2014-12-12 11:05:44.227 Error message from server (en): File not found
// ME - Used File List pane to change into the NewFiles folder (note: Folder shows as "/EDI/Emdeon/2014/NewFiles/"
. 2014-12-12 11:05:45.768 Cached directory change via "/EDI/Emdeon/2014/NewFiles/" to "/EDI/Emdeon/2014/NewFiles".
. 2014-12-12 11:05:45.768 Getting current directory name.
. 2014-12-12 11:05:45.768 Listing directory "/EDI/Emdeon/2014/NewFiles".
> 2014-12-12 11:05:45.768 Type: SSH_FXP_OPENDIR, Size: 34, Number: 2059
< 2014-12-12 11:05:45.848 Type: SSH_FXP_HANDLE, Size: 10, Number: 2059
> 2014-12-12 11:05:45.848 Type: SSH_FXP_READDIR, Size: 10, Number: 2316
< 2014-12-12 11:05:45.918 Type: SSH_FXP_NAME, Size: 331, Number: 2316
> 2014-12-12 11:05:45.918 Type: SSH_FXP_READDIR, Size: 10, Number: 2572
< 2014-12-12 11:05:46.048 Type: SSH_FXP_STATUS, Size: 22, Number: 2572
< 2014-12-12 11:05:46.058 Status code: 1
> 2014-12-12 11:05:46.058 Type: SSH_FXP_CLOSE, Size: 10, Number: 2820
// ME - NewFiles has two files in it, in the File pane they show as "/EDI/Emdeon/2014/NewFiles/h837.20141211.POD4.05173" and not as just "h837.20141211.POD4.05173"
. 2014-12-12 11:05:46.058 /EDI/Emdeon/2014/NewFiles/h837.20141211.POD4.05173;-;2445;2014-12-12T14:05:10.000Z;"user" [0];"group" [0];rw-rw-rw-;1
. 2014-12-12 11:05:46.058 /EDI/Emdeon/2014/NewFiles/m837.20141211.POD4.05175;-;8365;2014-12-12T14:05:10.000Z;"user" [0];"group" [0];rw-rw-rw-;1
. 2014-12-12 11:05:54.154 Closing connection.
. 2014-12-12 11:05:54.154 Sending special code: 12
. 2014-12-12 11:05:54.154 Sent EOF message
Thanks!
So it's SFTP server, not FTP.
Your SFTP server seems to use full path to a file in directory listing, instead of name-only, what violates the specification. That confuses WinSCP.
Quoting https://datatracker.ietf.org/doc/html/draft-ietf-secsh-filexfer-13:
A file name being returned (for SSH_FXP_READDIR, it will be a
relative name within the directory, without any path components;
for SSH_FXP_REALPATH it will be an absolute path name.)
What is your SFTP server? (You have removed that important information from the log).
lswalker85
Hey - Here's the removed connections. Since I don't own/manage this server I've removed Host and usernames.
. 2014-12-12 11:05:33.667 Session name: SPH (Site)
. 2014-12-12 11:05:33.667 Host name: [Removed]
. 2014-12-12 11:05:33.667 User name: [Removed] (Password: Yes, Key file: No)
. 2014-12-12 11:05:33.667 Tunnel: No
. 2014-12-12 11:05:33.667 Transfer Protocol: SFTP (SCP)
. 2014-12-12 11:05:33.667 Ping type: N, Ping interval: 30 sec; Timeout: 15 sec
. 2014-12-12 11:05:33.667 Proxy: none
. 2014-12-12 11:05:33.667 Send buffer: 262144
. 2014-12-12 11:05:33.667 SSH protocol version: 2; Compression: No
. 2014-12-12 11:05:33.667 Bypass authentication: No
. 2014-12-12 11:05:33.667 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2014-12-12 11:05:33.667 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2014-12-12 11:05:33.667 SSH Bugs: A,A,A,A,A,A,A,A,A,A
. 2014-12-12 11:05:33.667 Simple channel: Yes
. 2014-12-12 11:05:33.667 Return code variable: Autodetect; Lookup user groups: A
. 2014-12-12 11:05:33.667 Shell: default
. 2014-12-12 11:05:33.667 EOL: 0, UTF: 2
. 2014-12-12 11:05:33.667 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2014-12-12 11:05:33.667 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2014-12-12 11:05:33.667 SFTP Bugs: A,A
. 2014-12-12 11:05:33.667 SFTP Server: default
. 2014-12-12 11:05:33.677 Local directory: C:\, Remote directory: /EDI/Emdeon/2014, Update: Yes, Cache: Yes
. 2014-12-12 11:05:33.677 Cache directory changes: Yes, Permanent: Yes
. 2014-12-12 11:05:33.677 DST mode: 1; Timezone offset: 0h 0m
. 2014-12-12 11:05:33.677 --------------------------------------------------------------------------
. 2014-12-12 11:05:33.737 Looking up host "[Removed]"
. 2014-12-12 11:05:33.747 Connecting to [Removed] port [Removed]
. 2014-12-12 11:05:33.939 Server version: SSH-2.0-sshlib
. 2014-12-12 11:05:33.939 Using SSH protocol version 2
. 2014-12-12 11:05:33.939 We claim version: SSH-2.0-WinSCP_release_5.5.6
. 2014-12-12 11:05:34.009 Doing Diffie-Hellman group exchange
. 2014-12-12 11:05:34.209 Doing Diffie-Hellman key exchange with hash SHA-1
. 2014-12-12 11:05:34.600 Verifying host key [Removed]
. 2014-12-12 11:05:34.642 Host key matches cached key
. 2014-12-12 11:05:34.642 Host key fingerprint is:
. 2014-12-12 11:05:34.642 [Removed]
. 2014-12-12 11:05:34.642 Initialised AES-256 SDCTR client->server encryption
. 2014-12-12 11:05:34.642 Initialised HMAC-SHA1 client->server MAC algorithm
. 2014-12-12 11:05:34.642 Initialised AES-256 SDCTR server->client encryption
. 2014-12-12 11:05:34.642 Initialised HMAC-SHA1 server->client MAC algorithm
! 2014-12-12 11:05:34.932 Using username "[Removed]".
. 2014-12-12 11:05:35.012 Attempting keyboard-interactive authentication
. 2014-12-12 11:05:35.092 Prompt (6, SSH server authentication, Using keyboard-interactive authentication., Enter password: )
. 2014-12-12 11:05:35.092 Using stored password.
. 2014-12-12 11:05:35.232 Access granted
. 2014-12-12 11:05:35.232 Opening session as main channel
. 2014-12-12 11:05:35.305 Opened main channel
. 2014-12-12 11:05:35.375 Started a shell/command
Thanks!
It looks like some custom-built server.
Well, the server clearly violates the specification. And as it does not seem to be widely used, it's not worth investing to workaround on client-side. I'm sorry.
