Signing with PGP via WinSCP.com
jfrish
Is this possible via the command?
Here's what my WinSCP script looks like so far:
option batch abort
# Connect to SFTP server using a password
open sftp://Username:Password@ftp.server.com/
# Uploads all files in the dir
put C:\folderpath\* /FTPLocation/
# Disconnect
Or does the file need signed outside of WinSCP?
So... Looks like this is done with the PGP tools... I'm just hunting for a freebie CLI based tool.. so I can sign my file using a bat command.
Re: Signing with PGP via WinSCP.com
WinSCP cannot sign file with PGP. You have to do it before uploading the file using other tool.
