WinSCP put not working in script, but is working in CLI
Mentat
this is my first time trying scripting with WinSCP so pardon me if the question seems stupid.
i'm running the following script
option batch abort
open sftp://sftp:sftp@192.168.0.63/ -hostkey="ssh-rsa 1024 36:02:11:38:17:52:28:02:1e:eb:55:35:db:ed:ba:77"
put c:\test\*.*
and i get a premission denied, error code 3 each time.
however, if i do this manually i works every time
by manually i mean i run winscp.com
then paste: open sftp://sftp:sftp@192.168.0.63/ -hostkey="ssh-rsa 1024 36:02:11:38:17:52:28:02:1e:eb:55:35:db:ed:ba:77"
then paste put c:\test\*.*
i don't think there's a premission issue since i works manually, i searched for quite a while and i'm stumped.
Please help
Re: WinSCP put not working in script, but is working in CLI
Please attach a full log file for both scenarios (using the latest version of WinSCP).
Mentat
attached are the two logs
Description: This is the log when i start winscp manually and copy-paste each line from the script to the command line
Description: this is the log when i run the script
The only difference is that in manual log you upload to /, while in script log, you upload to /remotepath/. Well I assume that /remotepath is not a real path, but still it suggests that it's not /. That makes the logs incomparable. Please attach logs for really identical scenarios. Otherwise I must assume that you have a write access to /, but do not to /remotepath/.
Mentat
Hi Martin and thanks,
The problem is that i am using the exact same command in both cases:
"put c:\test\*.*"
i tested it right now and when i manually type "/remotepath" in winscp console i do get the same error message.
what i'm guessing is that for some reason within the script the put command is interpreted to contain a "/remotepath" as a destination parameter while in manual console it does not....
any ideas?
Oriel
"put c:\test\*.*"
That does not seem to be true, WinSCP logs the command as it is in the script file. It does not do any "interpretation".
> 2014-12-14 08:50:59.294 Script: put c:\test\*.* /remotepath/
Please double-check the file C:\Program Files (x86)\WinSCP\script.txt.
Mentat
this is an exact copy-paste from script.txt:
option batch abort
put c:\test\*.*
any ideas?
My only idea is that you are a victim of file system redirection (as this is about directory that normal account does not have a write access to).
If you run WinSCP (under the same local account as you run the script) and open the C:\Program Files (x86)\WinSCP\script.txt in its internal editor, does the file look the same?
