When using WebDAV on IIS with 5.6.3 beta
hajekj
hajekj avatar
Czech Republic
I have the following setup:
Windows Server 2012 R2, IIS 8.5 and WebDAV module on server
Windows 8.1 x64, WinSCP 5.6.3 beta on client
When I connect to the server using WebDAV, I can list the directories correctly, however when I try to download (or edit) a file, the file doesn't open, resulting with various HTTP errors. When I use Windows Explorer for WebDAV, it works without any issue.
Here are logs provided from IIS:
Using WinSCP
#Fields: date time s-ip cs-method cs-uri-stem cs-uri-query s-port cs-username c-ip cs(User-Agent) cs(Referer) sc-status sc-substatus sc-win32-status time-taken
2014-12-05 16:27:53 0.0.0.0 PROPFIND / - 443 administrator 0.0.0.0 WinSCP/5.6.3+neon/0.30.1 - 207 0 0 173
2014-12-05 16:27:54 0.0.0.0 GET /web.config - 443 - 0.0.0.0 WinSCP/5.6.3+neon/0.30.1 - 404 8 0 219
Same file opened using Windows Explorer
2014-12-05 16:36:21 0.0.0.0 PROPFIND / - 443 administrator 0.0.0.0 Microsoft-WebDAV-MiniRedir/6.3.9600 - 207 0 0 198
2014-12-05 16:36:23 0.0.0.0 GET /web.config - 443 administrator 0.0.0.0 Microsoft-WebDAV-MiniRedir/6.3.9600 - 200 0 0 229
Apparently, the authentication is missing when WinSCP is doing the GET request for the file.
Re: When using WebDAV on IIS with 5.6.3 beta
hajekj
hajekj avatar
Czech Republic
The logs should be below. Tried opening two files - index.html and test.php
[code:1:b36c705283]
. 2014-12-09 12:07:30.600 --------------------------------------------------------------------------
. 2014-12-09 12:07:30.600 WinSCP Version 5.6.3 (Build 4824) (OS 6.3.9600 - Windows 8.1 Pro)
. 2014-12-09 12:07:30.601 Configuration: J:\Applications\WinSCP\WinSCP.ini
. 2014-12-09 12:07:30.601 Local account: HAJEKJ-HP7300\Jan
. 2014-12-09 12:07:30.601 Working directory: J:\Applications\WinSCP
. 2014-12-09 12:07:30.601 Process ID: 5400
. 2014-12-09 12:07:30.601 Command-line: "J:\Applications\WinSCP\WinSCP.exe"
. 2014-12-09 12:07:30.601 Time zone: Current: GMT+1, Standard: GMT+1 (Central Europe Standard Time), DST: GMT+2 (Central Europe Daylight Time), DST Start: 3/30/2014, DST End: 10/26/2014
. 2014-12-09 12:07:30.601 Login time: Tuesday, December 9, 2014 12:07:30
. 2014-12-09 12:07:30.601 --------------------------------------------------------------------------
. 2014-12-09 12:07:30.601 Session name: My Server (WebDAV) (Site)
. 2014-12-09 12:07:30.601 Host name: server.domain.com (Port: 443)
. 2014-12-09 12:07:30.601 User name: user_account (Password: Yes, Key file: No)
. 2014-12-09 12:07:30.601 Transfer Protocol: WebDAV
. 2014-12-09 12:07:30.601 Proxy: none
. 2014-12-09 12:07:30.601 Local directory: default, Remote directory: /, Update: No, Cache: No
. 2014-12-09 12:07:30.601 Cache directory changes: No, Permanent: Yes
. 2014-12-09 12:07:30.601 DST mode: 1
. 2014-12-09 12:07:30.601 Compression: No
. 2014-12-09 12:07:30.663 HTTP session to https://server.domain.com:443 begins.
. 2014-12-09 12:07:30.663 ssl: SNI enabled by default.
. 2014-12-09 12:07:30.664 ah_create, for WWW-Authenticate
. 2014-12-09 12:07:30.664 Sending request headers:
. 2014-12-09 12:07:30.664 OPTIONS / HTTP/1.1. 2014-12-09 12:07:30.664 User-Agent: WinSCP/5.6.3 neon/0.30.1. 2014-12-09 12:07:30.664 Keep-Alive: . 2014-12-09 12:07:30.664 Connection: TE, Keep-Alive. 2014-12-09 12:07:30.664 TE: trailers. 2014-12-09 12:07:30.664 Host: server.domain.com. 2014-12-09 12:07:30.664 . 2014-12-09 12:07:30.664 Sending request-line and headers:
. 2014-12-09 12:07:30.664 Doing DNS lookup on server.domain.com...
. 2014-12-09 12:07:30.740 req: Connecting to 0.0.0.0:443
. 2014-12-09 12:07:30.915 Doing SSL negotiation.
. 2014-12-09 12:07:31.129 ssl: Verify callback @ 1 => 20
. 2014-12-09 12:07:31.129 ssl: Verify failures |= 8 => 8
. 2014-12-09 12:07:31.129 ssl: Verify callback @ 1 => 27
. 2014-12-09 12:07:31.318 Chain depth: 2
. 2014-12-09 12:07:31.318 ssl: Match common name '*.domain.com' against ''
. 2014-12-09 12:07:31.318 ssl: Match common name 'domain.com' against ''
. 2014-12-09 12:07:31.318 Identity match for '': bad
. 2014-12-09 12:07:31.318 ssl: Match common name 'StartCom Class 2 Primary Intermediate Server CA' against ''
. 2014-12-09 12:07:31.318 ssl: Match common name '*.domain.com' against 'server.domain.com'
. 2014-12-09 12:07:31.318 Identity match for 'server.domain.com': good
. 2014-12-09 12:07:31.318 Verifying certificate for "Jan Hajek, Zdar Nad Sazavou, Vysocina, CZ, o3Ru4FuLIeIn8rGw" with fingerprint 0d:86:1f:53:30:f1:10:ed:df:c0:30:9c:52:f8:fc:a1:76:03:c9:0b and 08 failures
. 2014-12-09 12:07:31.330 Certificate verified against Windows certificate store
. 2014-12-09 12:07:31.331 Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES256-SHA384, 4096 bit RSA
. 2014-12-09 12:07:31.331 Request sent; retry is 0.
. 2014-12-09 12:07:31.515 [status-line] < HTTP/1.1 200 OK. 2014-12-09 12:07:31.515 Header Name: [allow], Value: [OPTIONS, TRACE, GET, HEAD, POST, COPY, PROPFIND, LOCK, UNLOCK]
. 2014-12-09 12:07:31.515 Header Name: [server], Value: [Microsoft-IIS/8.5]
. 2014-12-09 12:07:31.515 Header Name: [public], Value: [OPTIONS, TRACE, GET, HEAD, POST, PROPFIND, PROPPATCH, MKCOL, PUT, DELETE, COPY, MOVE, LOCK, UNLOCK]
. 2014-12-09 12:07:31.515 Header Name: [dav], Value: [1,2,3]
. 2014-12-09 12:07:31.515 Header Name: [ms-author-via], Value: [DAV]
. 2014-12-09 12:07:31.515 Header Name: [date], Value: [Tue, 09 Dec 2014 11:07:44 GMT]
. 2014-12-09 12:07:31.515 Header Name: [content-length], Value: [0]
. 2014-12-09 12:07:31.515 End of headers.
. 2014-12-09 12:07:31.519 ah_post_send (#0), code is 200 (want 401), WWW-Authenticate is (none)
. 2014-12-09 12:07:31.519 Request ends, status 200 class 2xx, error line:
. 2014-12-09 12:07:31.519 200 OK
. 2014-12-09 12:07:31.519 Request ends.
. 2014-12-09 12:07:31.519 Server capabilities: 1, 2, 3
. 2014-12-09 12:07:31.519 --------------------------------------------------------------------------
. 2014-12-09 12:07:31.519 Using WebDAV protocol.
. 2014-12-09 12:07:31.519 Doing startup conversation with host.
. 2014-12-09 12:07:31.570 Changing directory to "/".
. 2014-12-09 12:07:31.570 Trying to open directory "/".
. 2014-12-09 12:07:31.570 ah_create, for WWW-Authenticate
> 2014-12-09 12:07:31.570 <?xml version="1.0" encoding="utf-8"?>
> 2014-12-09 12:07:31.570 <propfind xmlns="DAV:"><allprop/></propfind>
. 2014-12-09 12:07:31.570 Sending request headers:
. 2014-12-09 12:07:31.570 PROPFIND / HTTP/1.1. 2014-12-09 12:07:31.570 User-Agent: WinSCP/5.6.3 neon/0.30.1. 2014-12-09 12:07:31.570 Connection: TE. 2014-12-09 12:07:31.570 TE: trailers. 2014-12-09 12:07:31.570 Host: server.domain.com. 2014-12-09 12:07:31.570 Depth: 0. 2014-12-09 12:07:31.570 Content-Length: 84. 2014-12-09 12:07:31.570 Content-Type: application/xml. 2014-12-09 12:07:31.570 . 2014-12-09 12:07:31.570 Sending request-line and headers:
. 2014-12-09 12:07:31.570 Sending request body:
. 2014-12-09 12:07:31.570 Request sent; retry is 1.
. 2014-12-09 12:07:31.749 [status-line] < HTTP/1.1 401 Unauthorized. 2014-12-09 12:07:31.749 Header Name: [content-type], Value: [text/html]
. 2014-12-09 12:07:31.749 Header Name: [server], Value: [Microsoft-IIS/8.5]
. 2014-12-09 12:07:31.749 Header Name: [www-authenticate], Value: [Basic realm="server.domain.com"]
. 2014-12-09 12:07:31.749 Header Name: [date], Value: [Tue, 09 Dec 2014 11:07:44 GMT]
. 2014-12-09 12:07:31.749 Header Name: [content-length], Value: [1293]
. 2014-12-09 12:07:31.749 End of headers.
. 2014-12-09 12:07:31.749 ah_post_send (#0), code is 401 (want 401), WWW-Authenticate is Basic realm="server.domain.com"
. 2014-12-09 12:07:31.749 auth: Got challenge (code 401).
. 2014-12-09 12:07:31.749 auth: Got 'Basic' challenge.
. 2014-12-09 12:07:31.749 auth: Trying Basic challenge...
. 2014-12-09 12:07:31.749 auth: Accepted Basic challenge.
. 2014-12-09 12:07:31.749 auth: Sending 'Basic' response.
> 2014-12-09 12:07:31.749 <?xml version="1.0" encoding="utf-8"?>
> 2014-12-09 12:07:31.749 <propfind xmlns="DAV:"><allprop/></propfind>
. 2014-12-09 12:07:31.749 Sending request headers:
. 2014-12-09 12:07:31.749 PROPFIND / HTTP/1.1. 2014-12-09 12:07:31.749 User-Agent: WinSCP/5.6.3 neon/0.30.1. 2014-12-09 12:07:31.749 Connection: TE. 2014-12-09 12:07:31.749 TE: trailers. 2014-12-09 12:07:31.749 Host: server.domain.com. 2014-12-09 12:07:31.749 Depth: 0. 2014-12-09 12:07:31.749 Content-Length: 84. 2014-12-09 12:07:31.749 Content-Type: application/xml. 2014-12-09 12:07:31.749 Authorization: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx. 2014-12-09 12:07:31.749 . 2014-12-09 12:07:31.749 Sending request-line and headers:
. 2014-12-09 12:07:31.749 Sending request body:
. 2014-12-09 12:07:31.749 Request sent; retry is 1.
. 2014-12-09 12:07:31.925 [status-line] < HTTP/1.1 207 Multi Status. 2014-12-09 12:07:31.925 Header Name: [content-type], Value: [text/xml]
. 2014-12-09 12:07:31.925 Header Name: [server], Value: [Microsoft-IIS/8.5]
. 2014-12-09 12:07:31.925 Header Name: [date], Value: [Tue, 09 Dec 2014 11:07:44 GMT]
. 2014-12-09 12:07:31.925 Header Name: [content-length], Value: [846]
. 2014-12-09 12:07:31.925 End of headers.
. 2014-12-09 12:07:31.925 ah_post_send (#1), code is 207 (want 401), WWW-Authenticate is (none)
< 2014-12-09 12:07:31.926 <?xml version="1.0" encoding="utf-8"?><D:multistatus xmlns:D="DAV:"><D:response><D:href>https://server.domain.com/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Mon, 13 Oct 2014 08:37:08 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>/</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2014-03-08T21:08:14.302Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response></D:multistatus>
. 2014-12-09 12:07:31.926 Request ends, status 207 class 2xx, error line:
. 2014-12-09 12:07:31.926 207 Multi Status
. 2014-12-09 12:07:31.926 Request ends.
. 2014-12-09 12:07:31.926 Getting current directory name.
. 2014-12-09 12:07:32.039 ah_create, for WWW-Authenticate
. 2014-12-09 12:07:32.039 auth: Sending 'Basic' response.
> 2014-12-09 12:07:32.039 <?xml version="1.0" encoding="utf-8"?>
> 2014-12-09 12:07:32.039 <propfind xmlns="DAV:"><allprop/></propfind>
. 2014-12-09 12:07:32.039 Sending request headers:
. 2014-12-09 12:07:32.039 PROPFIND / HTTP/1.1. 2014-12-09 12:07:32.039 User-Agent: WinSCP/5.6.3 neon/0.30.1. 2014-12-09 12:07:32.039 Connection: TE. 2014-12-09 12:07:32.039 TE: trailers. 2014-12-09 12:07:32.039 Host: server.domain.com. 2014-12-09 12:07:32.039 Depth: 1. 2014-12-09 12:07:32.039 Content-Length: 84. 2014-12-09 12:07:32.039 Content-Type: application/xml. 2014-12-09 12:07:32.039 Authorization: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx. 2014-12-09 12:07:32.039 . 2014-12-09 12:07:32.039 Sending request-line and headers:
. 2014-12-09 12:07:32.039 Sending request body:
. 2014-12-09 12:07:32.039 Request sent; retry is 1.
. 2014-12-09 12:07:32.219 [status-line] < HTTP/1.1 207 Multi Status. 2014-12-09 12:07:32.220 Header Name: [content-type], Value: [text/xml]
. 2014-12-09 12:07:32.220 Header Name: [server], Value: [Microsoft-IIS/8.5]
. 2014-12-09 12:07:32.220 Header Name: [date], Value: [Tue, 09 Dec 2014 11:07:44 GMT]
. 2014-12-09 12:07:32.220 Header Name: [content-length], Value: [4822]
. 2014-12-09 12:07:32.220 End of headers.
. 2014-12-09 12:07:32.220 ah_post_send (#0), code is 207 (want 401), WWW-Authenticate is (none)
< 2014-12-09 12:07:32.220 <?xml version="1.0" encoding="utf-8"?><D:multistatus xmlns:D="DAV:"><D:response><D:href>https://server.domain.com/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Mon, 13 Oct 2014 08:37:08 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>/</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2014-03-08T21:08:14.302Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response><D:response><D:href>https://server.domain.com/hmailserver/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Wed, 26 Nov 2014 23:31:01 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>hmailserver</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2013-12-09T11:10:53.144Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response><D:response><D:href>https://server.domain.com/_websites/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Sat, 09 Aug 2014 06:08:19 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>_websites</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2013-12-03T20:12:38.449Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response><D:response><D:href>https://server.domain.com/index.html</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype>text/html</D:getcontenttype><D:getlastmodified>Fri, 05 Dec 2014 16:19:54 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag>"fd10d94da710d01:0"</D:getetag><D:displayname>index.html</D:displayname><D:getcontentlanguage/><D:getcontentlength>708</D:getcontentlength><D:iscollection>0</D:iscollection><D:creationdate>2014-04-08T21:53:18.439Z</D:creationdate><D:resourcetype/></D:prop></D:propstat></D:response><D:response><D:href>https://server.domain.com/phpmyadmin/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Sat, 21 Jun 2014 15:13:24 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>phpmyadmin</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2013-12-03T20:20:53.289Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response><D:response><D:href>https://server.domain.com/web.config</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype>application/octet-stream</D:getcontenttype><D:getlastmodified>Fri, 14 Nov 2014 20:30:53 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag>"80fcb6e2490d01:0"</D:getetag><D:displayname>web.config</D:displayname><D:getcontentlanguage/><D:getcontentlength>600</D:getcontentlength><D:iscollection>0</D:iscollection><D:creationdate>2014-11-14T20:30:53.0Z</D:creationdate><D:resourcetype/></D:prop></D:propstat></D:response></D:multistatus>
. 2014-12-09 12:07:32.220 Request ends, status 207 class 2xx, error line:
. 2014-12-09 12:07:32.220 207 Multi Status
. 2014-12-09 12:07:32.220 Request ends.
. 2014-12-09 12:07:32.220 ..;D;0;2014-10-13T08:37:08.000Z;"" [0];"" [0];---------;0
. 2014-12-09 12:07:32.220 hmailserver;D;0;2014-11-26T23:31:01.000Z;"" [0];"" [0];---------;0
. 2014-12-09 12:07:32.220 _websites;D;0;2014-08-09T06:08:19.000Z;"" [0];"" [0];---------;0
. 2014-12-09 12:07:32.220 index.html;-;708;2014-12-05T16:19:54.000Z;"" [0];"" [0];---------;0
. 2014-12-09 12:07:32.220 phpmyadmin;D;0;2014-06-21T15:13:24.000Z;"" [0];"" [0];---------;0
. 2014-12-09 12:07:32.220 web.config;-;600;2014-11-14T20:30:53.000Z;"" [0];"" [0];---------;0
. 2014-12-09 12:07:32.290 Startup conversation with host finished.
. 2014-12-09 12:07:32.403 Not refreshing directory, caching is off.
. 2014-12-09 12:07:48.462 File: '/index.html' [n/a] [708]
. 2014-12-09 12:07:48.463 Copying "/index.html" to local directory started.
. 2014-12-09 12:07:48.463 ah_create, for WWW-Authenticate
. 2014-12-09 12:07:48.463 auth: Sending 'Basic' response.
. 2014-12-09 12:07:48.463 Sending request headers:
. 2014-12-09 12:07:48.463 GET /index.html HTTP/1.1. 2014-12-09 12:07:48.463 User-Agent: WinSCP/5.6.3 neon/0.30.1. 2014-12-09 12:07:48.463 Connection: TE. 2014-12-09 12:07:48.463 TE: trailers. 2014-12-09 12:07:48.463 Host: server.domain.com. 2014-12-09 12:07:48.463 Authorization: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx. 2014-12-09 12:07:48.463 . 2014-12-09 12:07:48.463 Sending request-line and headers:
. 2014-12-09 12:07:48.463 Request sent; retry is 1.
. 2014-12-09 12:07:48.646 [status-line] < HTTP/1.1 200 OK. 2014-12-09 12:07:48.646 Header Name: [content-type], Value: [text/html]
. 2014-12-09 12:07:48.646 Header Name: [last-modified], Value: [Fri, 05 Dec 2014 16:19:54 GMT]
. 2014-12-09 12:07:48.646 Header Name: [accept-ranges], Value: [bytes]
. 2014-12-09 12:07:48.646 Header Name: [etag], Value: ["fd10d94da710d01:0"]
. 2014-12-09 12:07:48.646 Header Name: [server], Value: [Microsoft-IIS/8.5]
. 2014-12-09 12:07:48.646 Header Name: [date], Value: [Tue, 09 Dec 2014 11:08:01 GMT]
. 2014-12-09 12:07:48.646 Header Name: [content-length], Value: [708]
. 2014-12-09 12:07:48.646 End of headers.
. 2014-12-09 12:07:48.647 ah_post_send (#0), code is 200 (want 401), WWW-Authenticate is (none)
. 2014-12-09 12:07:48.647 Request ends.
. 2014-12-09 12:07:48.647 Preserving timestamp [2014-12-05T16:19:54.000Z]
. 2014-12-09 12:07:48.648 Transfer done: '/index.html' [708]
. 2014-12-09 12:07:55.054 Changing directory to "_websites".
. 2014-12-09 12:07:55.054 Trying to open directory "/_websites/".
. 2014-12-09 12:07:55.054 ah_create, for WWW-Authenticate
. 2014-12-09 12:07:55.054 auth: Sending 'Basic' response.
> 2014-12-09 12:07:55.054 <?xml version="1.0" encoding="utf-8"?>
> 2014-12-09 12:07:55.054 <propfind xmlns="DAV:"><allprop/></propfind>
. 2014-12-09 12:07:55.054 Sending request headers:
. 2014-12-09 12:07:55.054 PROPFIND /_websites/ HTTP/1.1. 2014-12-09 12:07:55.054 User-Agent: WinSCP/5.6.3 neon/0.30.1. 2014-12-09 12:07:55.054 Connection: TE. 2014-12-09 12:07:55.054 TE: trailers. 2014-12-09 12:07:55.054 Host: server.domain.com. 2014-12-09 12:07:55.054 Depth: 0. 2014-12-09 12:07:55.054 Content-Length: 84. 2014-12-09 12:07:55.054 Content-Type: application/xml. 2014-12-09 12:07:55.054 Authorization: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx. 2014-12-09 12:07:55.054 . 2014-12-09 12:07:55.054 Sending request-line and headers:
. 2014-12-09 12:07:55.054 Sending request body:
. 2014-12-09 12:07:55.054 Request sent; retry is 1.
. 2014-12-09 12:07:55.231 [status-line] < HTTP/1.1 207 Multi Status. 2014-12-09 12:07:55.231 Header Name: [content-type], Value: [text/xml]
. 2014-12-09 12:07:55.232 Header Name: [server], Value: [Microsoft-IIS/8.5]
. 2014-12-09 12:07:55.232 Header Name: [date], Value: [Tue, 09 Dec 2014 11:08:07 GMT]
. 2014-12-09 12:07:55.232 Header Name: [content-length], Value: [864]
. 2014-12-09 12:07:55.232 End of headers.
. 2014-12-09 12:07:55.232 ah_post_send (#0), code is 207 (want 401), WWW-Authenticate is (none)
< 2014-12-09 12:07:55.232 <?xml version="1.0" encoding="utf-8"?><D:multistatus xmlns:D="DAV:"><D:response><D:href>https://server.domain.com/_websites/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Sat, 09 Aug 2014 06:08:19 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>_websites</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2013-12-03T20:12:38.449Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response></D:multistatus>
. 2014-12-09 12:07:55.232 Request ends, status 207 class 2xx, error line:
. 2014-12-09 12:07:55.232 207 Multi Status
. 2014-12-09 12:07:55.232 Request ends.
. 2014-12-09 12:07:55.232 Getting current directory name.
. 2014-12-09 12:07:55.232 ah_create, for WWW-Authenticate
. 2014-12-09 12:07:55.232 auth: Sending 'Basic' response.
> 2014-12-09 12:07:55.232 <propfind xmlns="DAV:"><allprop/></propfind>
. 2014-12-09 12:07:55.232 Sending request headers:
. 2014-12-09 12:07:55.232 PROPFIND /_websites/ HTTP/1.1. 2014-12-09 12:07:55.232 User-Agent: WinSCP/5.6.3 neon/0.30.1. 2014-12-09 12:07:55.232 Connection: TE. 2014-12-09 12:07:55.232 TE: trailers. 2014-12-09 12:07:55.232 Host: server.domain.com. 2014-12-09 12:07:55.232 Depth: 1. 2014-12-09 12:07:55.232 Content-Length: 84. 2014-12-09 12:07:55.232 Content-Type: application/xml. 2014-12-09 12:07:55.232 Authorization: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx. 2014-12-09 12:07:55.232 . 2014-12-09 12:07:55.232 Sending request-line and headers:
. 2014-12-09 12:07:55.232 Sending request body:
. 2014-12-09 12:07:55.232 Request sent; retry is 1.
. 2014-12-09 12:07:55.413 [status-line] < HTTP/1.1 207 Multi Status. 2014-12-09 12:07:55.413 Header Name: [content-type], Value: [text/xml]
. 2014-12-09 12:07:55.413 Header Name: [server], Value: [Microsoft-IIS/8.5]
. 2014-12-09 12:07:55.413 Header Name: [date], Value: [Tue, 09 Dec 2014 11:08:07 GMT]
. 2014-12-09 12:07:55.413 Header Name: [content-length], Value: [3286]
. 2014-12-09 12:07:55.413 End of headers.
. 2014-12-09 12:07:55.413 ah_post_send (#0), code is 207 (want 401), WWW-Authenticate is (none)
< 2014-12-09 12:07:55.413 <?xml version="1.0" encoding="utf-8"?><D:multistatus xmlns:D="DAV:"><D:response><D:href>https://server.domain.com/_websites/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Sat, 09 Aug 2014 06:08:19 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>_websites</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2013-12-03T20:12:38.449Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response><D:response><D:href>https://server.domain.com/_websites/domain.com/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Mon, 13 Oct 2014 08:24:25 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>domain.com</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2013-12-03T20:17:14.988Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response><D:response><D:href>https://server.domain.com/_websites/test.service.domain.com/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Thu, 14 Aug 2014 09:50:53 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>test.service.domain.com</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2014-05-02T17:07:55.895Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response><D:response><D:href>https://server.domain.com/_websites/domainn2.com/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Sat, 09 Aug 2014 06:08:30 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>domain2.com</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2014-08-09T06:08:15.429Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response></D:multistatus>
. 2014-12-09 12:07:55.413 Request ends, status 207 class 2xx, error line:
. 2014-12-09 12:07:55.413 207 Multi Status
. 2014-12-09 12:07:55.413 Request ends.
. 2014-12-09 12:07:55.414 domain.com;D;0;2014-10-13T08:24:25.000Z;"" [0];"" [0];---------;0
. 2014-12-09 12:07:55.414 test.service.domain.com;D;0;2014-08-14T09:50:53.000Z;"" [0];"" [0];---------;0
. 2014-12-09 12:07:55.414 domain2.com;D;0;2014-08-09T06:08:30.000Z;"" [0];"" [0];---------;0
. 2014-12-09 12:07:56.519 Changing directory to "domain.com".
. 2014-12-09 12:07:56.519 Trying to open directory "/_websites/domain.com/".
. 2014-12-09 12:07:56.519 ah_create, for WWW-Authenticate
. 2014-12-09 12:07:56.519 auth: Sending 'Basic' response.
> 2014-12-09 12:07:56.519 <?xml version="1.0" encoding="utf-8"?>
> 2014-12-09 12:07:56.519 <propfind xmlns="DAV:"><allprop/></propfind>
. 2014-12-09 12:07:56.519 Sending request headers:
. 2014-12-09 12:07:56.519 PROPFIND /_websites/domain.com/ HTTP/1.1. 2014-12-09 12:07:56.519 User-Agent: WinSCP/5.6.3 neon/0.30.1. 2014-12-09 12:07:56.519 Connection: TE. 2014-12-09 12:07:56.519 TE: trailers. 2014-12-09 12:07:56.519 Host: server.domain.com. 2014-12-09 12:07:56.519 Depth: 0. 2014-12-09 12:07:56.519 Content-Length: 84. 2014-12-09 12:07:56.519 Content-Type: application/xml. 2014-12-09 12:07:56.519 Authorization: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx. 2014-12-09 12:07:56.519 . 2014-12-09 12:07:56.519 Sending request-line and headers:
. 2014-12-09 12:07:56.519 Sending request body:
. 2014-12-09 12:07:56.519 Request sent; retry is 1.
. 2014-12-09 12:07:56.698 [status-line] < HTTP/1.1 207 Multi Status. 2014-12-09 12:07:56.698 Header Name: [content-type], Value: [text/xml]
. 2014-12-09 12:07:56.698 Header Name: [server], Value: [Microsoft-IIS/8.5]
. 2014-12-09 12:07:56.698 Header Name: [date], Value: [Tue, 09 Dec 2014 11:08:09 GMT]
. 2014-12-09 12:07:56.698 Header Name: [content-length], Value: [874]
. 2014-12-09 12:07:56.698 End of headers.
. 2014-12-09 12:07:56.698 ah_post_send (#0), code is 207 (want 401), WWW-Authenticate is (none)
< 2014-12-09 12:07:56.698 <?xml version="1.0" encoding="utf-8"?><D:multistatus xmlns:D="DAV:"><D:response><D:href>https://server.domain.com/_websites/domain.com/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Mon, 13 Oct 2014 08:24:25 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>domain.com</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2013-12-03T20:17:14.988Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response></D:multistatus>
. 2014-12-09 12:07:56.698 Request ends, status 207 class 2xx, error line:
. 2014-12-09 12:07:56.698 207 Multi Status
. 2014-12-09 12:07:56.698 Request ends.
. 2014-12-09 12:07:56.698 Getting current directory name.
. 2014-12-09 12:07:56.698 ah_create, for WWW-Authenticate
. 2014-12-09 12:07:56.698 auth: Sending 'Basic' response.
> 2014-12-09 12:07:56.698 <propfind xmlns="DAV:"><allprop/></propfind>
. 2014-12-09 12:07:56.698 Sending request headers:
. 2014-12-09 12:07:56.698 PROPFIND /_websites/domain.com/ HTTP/1.1. 2014-12-09 12:07:56.698 User-Agent: WinSCP/5.6.3 neon/0.30.1. 2014-12-09 12:07:56.698 Connection: TE. 2014-12-09 12:07:56.698 TE: trailers. 2014-12-09 12:07:56.698 Host: server.domain.com. 2014-12-09 12:07:56.698 Depth: 1. 2014-12-09 12:07:56.698 Content-Length: 84. 2014-12-09 12:07:56.698 Content-Type: application/xml. 2014-12-09 12:07:56.698 Authorization: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx. 2014-12-09 12:07:56.698 . 2014-12-09 12:07:56.698 Sending request-line and headers:
. 2014-12-09 12:07:56.699 Sending request body:
. 2014-12-09 12:07:56.699 Request sent; retry is 1.
. 2014-12-09 12:07:56.882 [status-line] < HTTP/1.1 207 Multi Status. 2014-12-09 12:07:56.882 Header Name: [content-type], Value: [text/xml]
. 2014-12-09 12:07:56.882 Header Name: [server], Value: [Microsoft-IIS/8.5]
. 2014-12-09 12:07:56.882 Header Name: [date], Value: [Tue, 09 Dec 2014 11:08:09 GMT]
. 2014-12-09 12:07:56.882 Header Name: [content-length], Value: [6570]
. 2014-12-09 12:07:56.882 End of headers.
. 2014-12-09 12:07:56.883 ah_post_send (#0), code is 207 (want 401), WWW-Authenticate is (none)
< 2014-12-09 12:07:56.883 <?xml version="1.0" encoding="utf-8"?><D:multistatus xmlns:D="DAV:"><D:response><D:href>https://server.domain.com/_websites/domain.com/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Mon, 13 Oct 2014 08:24:25 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>domain.com</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2013-12-03T20:17:14.988Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response><D:response><D:href>https://server.domain.com/_websites/domain.com/customers.domain.com/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Wed, 22 Oct 2014 15:43:46 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>customers.domain.com</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2013-12-04T01:15:54.487Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response><D:response><D:href>https://server.domain.com/_websites/domain.com/honza.domain.com/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Wed, 03 Dec 2014 21:32:58 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>honza.domain.com</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2013-12-04T00:44:30.343Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response><D:response><D:href>https://server.domain.com/_websites/domain.com/lsl.domain.com/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Tue, 09 Sep 2014 12:51:32 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>lsl.domain.com</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2013-12-04T13:55:12.487Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response><D:response><D:href>https://server.domain.com/_websites/domain.com/products.domain.com/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Mon, 23 Jun 2014 14:40:49 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>products.domain.com</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2013-12-14T08:16:50.458Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response><D:response><D:href>https://server.domain.com/_websites/domain.com/server.domain.com/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Mon, 13 Oct 2014 08:37:08 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>server.domain.com</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2014-03-08T21:08:14.302Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response><D:response><D:href>https://server.domain.com/_websites/domain.com/vendors.domain.com/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Sun, 27 Apr 2014 09:24:38 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>vendors.domain.com</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2013-12-03T23:17:50.349Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response><D:response><D:href>https://server.domain.com/_websites/domain.com/www.domain.com/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Mon, 08 Dec 2014 19:49:22 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>www.domain.com</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2013-12-03T21:48:46.970Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response></D:multistatus>
. 2014-12-09 12:07:56.883 Request ends, status 207 class 2xx, error line:
. 2014-12-09 12:07:56.883 207 Multi Status
. 2014-12-09 12:07:56.883 Request ends.
. 2014-12-09 12:07:56.883 customers.domain.com;D;0;2014-10-22T15:43:46.000Z;"" [0];"" [0];---------;0
. 2014-12-09 12:07:56.883 honza.domain.com;D;0;2014-12-03T21:32:58.000Z;"" [0];"" [0];---------;0
. 2014-12-09 12:07:56.883 lsl.domain.com;D;0;2014-09-09T12:51:32.000Z;"" [0];"" [0];---------;0
. 2014-12-09 12:07:56.883 products.domain.com;D;0;2014-06-23T14:40:49.000Z;"" [0];"" [0];---------;0
. 2014-12-09 12:07:56.883 server.domain.com;D;0;2014-10-13T08:37:08.000Z;"" [0];"" [0];---------;0
. 2014-12-09 12:07:56.883 vendors.domain.com;D;0;2014-04-27T09:24:38.000Z;"" [0];"" [0];---------;0
. 2014-12-09 12:07:56.883 www.domain.com;D;0;2014-12-08T19:49:22.000Z;"" [0];"" [0];---------;0
. 2014-12-09 12:07:59.278 Changing directory to "honza.domain.com".
. 2014-12-09 12:07:59.278 Trying to open directory "/_websites/domain.com/honza.domain.com/".
. 2014-12-09 12:07:59.279 ah_create, for WWW-Authenticate
. 2014-12-09 12:07:59.279 auth: Sending 'Basic' response.
> 2014-12-09 12:07:59.279 <?xml version="1.0" encoding="utf-8"?>
> 2014-12-09 12:07:59.279 <propfind xmlns="DAV:"><allprop/></propfind>
. 2014-12-09 12:07:59.279 Sending request headers:
. 2014-12-09 12:07:59.279 PROPFIND /_websites/domain.com/honza.domain.com/ HTTP/1.1. 2014-12-09 12:07:59.279 User-Agent: WinSCP/5.6.3 neon/0.30.1. 2014-12-09 12:07:59.279 Connection: TE. 2014-12-09 12:07:59.279 TE: trailers. 2014-12-09 12:07:59.279 Host: server.domain.com. 2014-12-09 12:07:59.279 Depth: 0. 2014-12-09 12:07:59.279 Content-Length: 84. 2014-12-09 12:07:59.279 Content-Type: application/xml. 2014-12-09 12:07:59.279 Authorization: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx. 2014-12-09 12:07:59.279 . 2014-12-09 12:07:59.279 Sending request-line and headers:
. 2014-12-09 12:07:59.279 Sending request body:
. 2014-12-09 12:07:59.279 Request sent; retry is 1.
. 2014-12-09 12:07:59.455 [status-line] < HTTP/1.1 207 Multi Status. 2014-12-09 12:07:59.455 Header Name: [content-type], Value: [text/xml]
. 2014-12-09 12:07:59.455 Header Name: [server], Value: [Microsoft-IIS/8.5]
. 2014-12-09 12:07:59.455 Header Name: [date], Value: [Tue, 09 Dec 2014 11:08:12 GMT]
. 2014-12-09 12:07:59.455 Header Name: [content-length], Value: [896]
. 2014-12-09 12:07:59.455 End of headers.
. 2014-12-09 12:07:59.455 ah_post_send (#0), code is 207 (want 401), WWW-Authenticate is (none)
< 2014-12-09 12:07:59.455 <?xml version="1.0" encoding="utf-8"?><D:multistatus xmlns:D="DAV:"><D:response><D:href>https://server.domain.com/_websites/domain.com/honza.domain.com/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Wed, 03 Dec 2014 21:32:58 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>honza.domain.com</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2013-12-04T00:44:30.343Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response></D:multistatus>
. 2014-12-09 12:07:59.455 Request ends, status 207 class 2xx, error line:
. 2014-12-09 12:07:59.455 207 Multi Status
. 2014-12-09 12:07:59.455 Request ends.
. 2014-12-09 12:07:59.455 Getting current directory name.
. 2014-12-09 12:07:59.456 ah_create, for WWW-Authenticate
. 2014-12-09 12:07:59.456 auth: Sending 'Basic' response.
> 2014-12-09 12:07:59.456 <?xml version="1.0" encoding="utf-8"?>
> 2014-12-09 12:07:59.456 <propfind xmlns="DAV:"><allprop/></propfind>
. 2014-12-09 12:07:59.456 Sending request headers:
. 2014-12-09 12:07:59.456 PROPFIND /_websites/domain.com/honza.domain.com/ HTTP/1.1. 2014-12-09 12:07:59.456 User-Agent: WinSCP/5.6.3 neon/0.30.1. 2014-12-09 12:07:59.456 Connection: TE. 2014-12-09 12:07:59.456 TE: trailers. 2014-12-09 12:07:59.456 Host: server.domain.com. 2014-12-09 12:07:59.456 Depth: 1. 2014-12-09 12:07:59.456 Content-Length: 84. 2014-12-09 12:07:59.456 Content-Type: application/xml. 2014-12-09 12:07:59.456 Authorization: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx. 2014-12-09 12:07:59.456 . 2014-12-09 12:07:59.456 Sending request-line and headers:
. 2014-12-09 12:07:59.456 Sending request body:
. 2014-12-09 12:07:59.456 Request sent; retry is 1.
. 2014-12-09 12:07:59.638 [status-line] < HTTP/1.1 207 Multi Status. 2014-12-09 12:07:59.638 Header Name: [content-type], Value: [text/xml]
. 2014-12-09 12:07:59.638 Header Name: [server], Value: [Microsoft-IIS/8.5]
. 2014-12-09 12:07:59.638 Header Name: [date], Value: [Tue, 09 Dec 2014 11:08:12 GMT]
. 2014-12-09 12:07:59.638 Header Name: [content-length], Value: [5089]
. 2014-12-09 12:07:59.638 End of headers.
. 2014-12-09 12:07:59.638 ah_post_send (#0), code is 207 (want 401), WWW-Authenticate is (none)
< 2014-12-09 12:07:59.638 <?xml version="1.0" encoding="utf-8"?><D:multistatus xmlns:D="DAV:"><D:response><D:href>https://server.domain.com/_websites/domain.com/honza.domain.com/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Wed, 03 Dec 2014 21:32:58 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>honza.domain.com</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2013-12-04T00:44:30.343Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response><D:response><D:href>https://server.domain.com/_websites/domain.com/honza.domain.com/cURL.php</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype>application/octet-stream</D:getcontenttype><D:getlastmodified>Thu, 19 Jun 2014 21:46:24 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag>"d780d9ea78ccf1:0"</D:getetag><D:displayname>cURL.php</D:displayname><D:getcontentlanguage/><D:getcontentlength>4118</D:getcontentlength><D:iscollection>0</D:iscollection><D:creationdate>2014-02-27T07:23:43.390Z</D:creationdate><D:resourcetype/></D:prop></D:propstat></D:response><D:response><D:href>https://server.domain.com/_websites/domain.com/honza.domain.com/SecondLife/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Sat, 15 Feb 2014 12:03:06 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>SecondLife</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2013-12-04T00:44:44.645Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response><D:response><D:href>https://server.domain.com/_websites/domain.com/honza.domain.com/TacMap/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Sun, 07 Dec 2014 11:12:17 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>TacMap</D:displayname><D:getcontentlanguage/>
Thanks for the log. Though I can see only download of index.html in the log and that worked ok.
Anyway, the problem might be fixed by following improvement:
https://winscp.net/tracker/1255
I have sent you an email with a development version of WinSCP to address you have used to register on this forum.
