File not found when processing in task scheduler on Windows
jnollet
MA
I have successfully used WinSCP to transfer files in batch files before
but now I am having difficulty with the job in the task scheduler.
I use the simple command:
call "C:\Program Files (x86)\WinSCP\WinSCP.exe" BoA /upload C_PM_*.DAT /defaults
BoA is a session configured to connect local folder to remote host (a bank specifically)
The file is in the local folder as C_PM_20141203102112.DAT
This step in my batch file never completes and only ends when forcibly stopped.
I attached a log of the session to this post.
Description: WinSCP log
Re: File not found when processing in task scheduler on Windows
Does the file exist in Z:\ folder (the current working folder)?
jnollet
MA
I resolved this!! thanks
I was able to resolve the issue.
the problem was that the task scheduler doesn't like Mapped drives and the winscp.exe doesn't like UNC coding ...
what I did was to script the SFTP steps using winscp.com and move the files to local directories before executing those steps... it causes some extra cleanup but it works now.
Thanks again
John
_________________
JCN
