Filepart
Cocono1
Filepart
Hi there,
I am currently transferring a file via a batch file. The file of over 100K so WINSCP is adding .filepart which is causing an issue for the person I am transferring the file to.
How do I prevent this in my batch code?
I have about read -resumesupport as below but I don't understand how to apply this
To configure transfer to temporary file name in scripting, use -resumesupport switch of file transfer commands
My command looks like:
winscp.com /command "option batch abort" "option confirm off" "open test:test@test.com/" "put testfile.csv /foldernew/" "exit"
Re: Filepart
Use:
winscp.com /command "option batch abort" "option confirm off" "open test:test@test.com/" "put -resumesupport=off testfile.csv /foldernew/" "exit"
