Authentication Banner keeps appearing
DavidMacLean
Version 5.5.4
When I click the 'Never show this banner again' for the Authentication Banner it doesn't save that selection? Every time I open the session I get the Banner?
Reply with quote E-mail
Re: Authentication Banner keeps appearing
It prevents only an identical banner from appearing the next time. I assume your banner changes (it may display current time or free disk space or other ever changing information).
DavidMacLean
Unless there is hidden data on the banner it looks the same every time with a simple one line header. This is happening on version 5.5.4 but works on version 4.2.9.
This is happening when I run it manually - GUI. But I'm worried about my scripts hanging on this. Can this be handled in a script somehow?
WinSCP does not display banners in script.
Btw, are you running 4.2.9 and 5.5.4 on the same machine? That would explain the problem. Each version (4.x vs. 5.x) uses a different encoding, so checksum of banners are different. And each version consider checksum of the banner calculated by the other version different.
