WebDAV client problem with Authentication
webuser
The WebDAV client in WinSCP is a must have! I love this function.
Nevertheless, I have some troubles with the authentication with some quite old servers (Novell Webfiles). The problem is that the client is trying to authenticate with the root path of the web server (like "https://www.example.com/"), but these servers can't authenticate to this URL. Instead, they need to use the full path of the user (like "https://www.example.com/oneNet/NetStorage"). I put the full path in the configuration of the site at the entry "Remote Directory", but the logs show that the client is authenticating only to the root path.
Please, can include some modification (a option) to use the full path of the remote directory in the authentication process?
Thank you!
Re: WebDAV client problem with Authentication
