Facing problem to get recent file
Prashanth
Hi
I wanted to download the most recent file from the remote directory please see the below script:
get filemask="*>1d"
get filemask="*<1d"
I used both the scripts but the result is same like it downloads all the files from remote directory.
And even my question is how to pass the specific timestamp into my script or batch file.
Please help me to sort out from this.
Prashanth
Re: Facing problem to get recent file
First you are missing a dash before filemask. It should be:
get -filemask="*>1d"
Second that command does not download the most recent file, it downloads all files created/modified in the last 24 hours. What may happen to be all files in the directory.
To download the most recent file, refer to:
Downloading the most recent file
and even my question is how to pass the specific timestamp into my script or batch file.
That's quite broad question.
See
https://winscp.net/eng/docs/scripting#arguments
https://winscp.net/eng/docs/script_upload_multiple_servers
Harinath
Filemask not working
Hi
I need to setup file transfer at 10secs interval and transfer only the new files added to the folder since.
My following script is transferring all files and somehow filemask is not working.
#copy  entire folder
put -filemask="*>=10S" *
Re: Filemask not working
@Harinath: Start a new thread and include a full script log file.
Though what you are doing is imho a bad idea. You may miss some files with such a tight schedule.
BRichmond
Relative time, e.g. -filemask="*>=1D"
If I use -filemask="*>=1D", does that compare just the day component of time, or does it compare using 24 hours? Example, if source file was created 25 hours ago at 7am my time yesterday, if I do a get using *>=1D, will that file get picked up? The date is one day old, but the time is more than 24 hours ago. Thanks.
Trupti B
Facing the problem to download the latest file
Hi
# it downloads all the files.
get -latest
# it downloads all files created/modified in the last 24
get -filemask="file_name_*>=1D" hours.
# it downloads all files created/modified in the last 24 hours.
get -latest -filemask="file_name_*>=1D"
As files are not uploaded on daily basis that's why above scripts are not working. Suppose I have uploaded the last file on 23rd July and today is 28th July, I want to download the 23rd July file.
Is it possible to download the 23rd July file?
Re: Facing the problem to download the latest file
@TruptiB: I'm not sure I follow. Are you asking for WinSCP to detect, what file was the last one uploaded, even if there are other files with later timestamp?
The best would be if you post a session log file (use /log=C:\path\to\winscp.log command-line argument) and give us a name of the file you wanted to upload and describe what was uploaded instead.
