Can´t find checksum method in .NET / COM Library
Pif
Hello everbody,
In the GUI you can right-click a file or folder and then switch to the checksum tab to see/calculate checksums.
I would like to use this functionality programatically through the .NET/COM Library.
I looked through the API but was unable to find the method to trigger this.
Is this contained in the API at all? (I tried up to 5.6.2 beta)
Thanks a lot.
Pif
Re: Can´t find checksum method in .NET / COM Library
No. It's not contained in the API. Will try to add it. I can email you a dev version once it is done, if you register on this forum.
pif
Frankfurt
That would be fantastic. I am now registered as Pif. Thank you so much!
