Keep Remote Directory up2date doesn't work on network drive
vielhuber
Hello!
I am connected to a ftp-server and use the awesome feature "Keep Remote Directory up to Date".
It works like a charm when I monitor a local folder on my hard drive.
The problem is if I choose instead a folder on a mapped network drive (also here in my local environment),
it seems that after 1 minute or so WinSCP simply does not recognize any changes to the files anymore.
If I change a file, nothing happens (it is not uploaded at all).
Only in the first minute everything works as expected.
Do you know this behaviour and what can I do to prevent it?
Thanks in advance
Re: Keep Remote Directory up2date doesn't work on network drive
