Zero Byte files using command interface, ok in GUI
whatusername
Hi
Im using WINSCP v5.6.2 build 4756
When I try a 'get' or 'synchronise' using the script command interface I get zero byte files transfered.
If I use the GUI interface all transfers ok.
Im attaching a .rar file which comtains :
commandtest_CONCUR_DOWNLOAD_sFTP_20141107110037.log - script out put log
commandtest_WINSCP_DOWNLOAD_CONCUR_SFTP.txt - command options used to connect
guitest_Concur_sftp.log - normal log mode in gui
guitest_Concur_sftp_debug1.log - debug1 log mode in gui
guitest_Concur_sftp_debug2.log - debug2 log mode in gui
Can someone help me please ?
Many thanks
  • sftp_zero_byte_file_logs.rar (943.6 KB, Private file)
Re: Zero Byte files using command interface, ok in GUI
It's indeed strange.
The only difference I could spot is that you are using /OUT in script, while /out in GUI. I cannot imagine how this could make a difference, but can you anyway try using /out in the script?
whatusername
Wow , your advice was absolutely correct !!!!
I'm amazed , but there we are , it now functions correctly
Many thanks for your help and quick response
