Powershell SynchronizeDirectories
I try to sync a local directory by using the .NET Assembly with powershell.
After setting the SessionOptions, this is what I do:
I do not know what is wrong, I am using the example of this page (with the change from Remote to Local Sync).
When I do a ListDirectory of the source everything is fine.
Could somebody give me a hint?
Thank you very much in advance.
BR
Matthias
$session = New-Object WinSCP.Session $session.SessionLogPath = ".\SessionLogFile.log" $session.Open($sessionOptions) $session.SynchronizeDirectories([WinSCP.SynchronizationMode]::Local, "/storage/hd0b/wm/config_backup", ".\config_backup", $True, $True) Uploads : {} Downloads : {} Removals : {} Failures : {WinSCP.SessionRemoteException: Error listing directory '/storage/hd0b/wm/config_backup'. ---> WinSCP.Sessi onRemoteException: Error retrieving file list for "/storage/hd0b/wm/config_backup\*.*". System Error. Code: 3. Das System kann den angegebenen Pfad nicht finden --- Ende der internen Ausnahmestapelüberwachung ---, WinSCP.SessionRemoteException: Error listing direct ory '/storage/hd0b/wm/config_backup'. ---> WinSCP.SessionRemoteException: Error retrieving file list for "/ storage/hd0b/wm/config_backup\*.*". System Error. Code: 3. Das System kann den angegebenen Pfad nicht finden --- Ende der internen Ausnahmestapelüberwachung ---} IsSuccess : False
$session.ListDirectory("/storage/hd0b/wm/config_backup") Files ----- {config_20140515_2030.tar.gz, config_20140904_2030.tar.gz, config_20140626_2030.tar.gz, config_20141106_2030.tar.gz...}
BR
Matthias
