"Syntax hightlight" plugin
Oscar
Is there a possibility to write a "syntax hightlight" plugin for internal editor in WinScp?
I need this for php, but it doesn't matter actually.
Reply with quote E-mail
Re: "Syntax hightlight" plugin
I fear that this would blow size of the application too much. You may use external editor that has highlighting.
ago
For Oscar, as suggested select the editor you prefer (scite, gvim are good choises) in the options and you are done....
Actually I feel the internal editor is not needed... I do not see any advantage over external ones. It is IMO much more important to be able to open/edit multiple documents simultaneously without locking everything...
Already implemented in 3.6.7, released today.
