logs to XML
malva
logs to XML
Hi!
I have a problem with logs to xml.
I'm using $session.XmlLogPath = "D:\ftps\log.xml"
When I'm creating empty log.xml file and running script, it gives me: "Configured temporary file D:\ftps\log.xml already exist".
When there's no log.xml file, after running script no file is created with log.
Anybody could help?
Re: logs to XML
The XML log is used internally by the WinSCP .NET assembly. The assembly deletes the (temporary) log, when the session closes.
The Session.XmlLogPath is not part of the assembly public interface. It's available for debugging purposes only.
What are you trying to do?
