unknown command '?option'
paultp
I have a strange error that happens once in a while, the Winscp commad runs just fine almost all of the times, but on few occassions, it throws this error in (see it from the log files):
2014-10-23 04:34:08.800 Script: Retrospectively logging previous script records:
> 2014-10-23 04:34:08.800 Script: ?option batch abort
< 2014-10-23 04:34:08.800 Script: Unknown command '?option'.
. 2014-10-23 04:34:08.800 Script: Failed
> 2014-10-23 04:34:08.800 Script: option confirm off
< 2014-10-23 04:34:08.800 Script: confirm off
> 2014-10-23 04:34:08.800 Script: open CloudBrickFTPS
This is the actual script commad that runs just fine all the time except on couple of these ocassions where it is failing:
option batch abort
open CloudBrickFTPS
Get /folder1/ C:\Receive\
close
Why is the "?" mark being introduced in the script sometimes just "randomly?"
Thank you for any ideas.
Paul
Re: unknown command '?option'
The ? may stand for UTF-8 BOM at the beginning of the file. Though WinSCP should be able to strip it, if present. Can you attach a complete log files from a run it succeeds and a run it fails?
paultp
Thank you Martin. I've attached the log file.
  • WinScpLog.txt (6.8 KB, Private file)
paultp
Attached is the log for a successful operation.
It is interesting that it happens randomly. Any help would be appreciated, as we will be going live in few days.
Thanks Martin.
Thanks Martin.
Adding the success attachment next.
Thanks Martin.
Sorry the one that is attached is the error log again. Now attaching the success log.
paultp
Thanks Martin.
One more thing to note in this issue is that the error never happens during the upload of the file (SFTP via Winscp to a remote location always is going well), but the problem happens during the download (Receive the file SFTP with WinSCP from the remote location to a local machine)
How do you provide commands to WinSCP? Are you redirecting a standard input? (I do not see any /command or /script parameters)
Hi Martin,
Thanks. I am using through an SSIS SQL package. Using a StandardInputVariable, and the variable has the command script like:
"option batch abort " + "\n" + "option confirm off" + "\n" + "open CloudBrickFTPS " + "\n" + " Get " + @[User::FTPDirectory] + @[User::BakFileName] + " " + @[User::ReceivePath] +"\n" + " close " + "\n" + " exit"
And the executable is pointing to: C:\Program Files (x86)\WinSCP\WinSCP.com
This issue happened again, and immediately after the failure, I re-ran , and it ran successfully. I am a little stumped! I am also attaching the log (with both failure and the following success).
We are going live in 2 days. Appreciate your help.
Thanks again.
Paul
  • Winscp-11-5-14.txt (29.58 KB, Private file)
As a workaround, can you try to assemble a command-line string using your code rather than the standard input string?
paultp1
Hi Martin,
I am trying to install the debug, but have a question before I do:
I already have the regular Winscp program that the production server is using ( where the random error happens); shall I install the debug version on the same box? It seems like so. But, on to the point of reproducing the error, will the debug automatically capture the traces when the actual production process using the "production Winscp" runs and eventually errors? Or do I have to change my production Winscp to point to the debug release version?
Thanks so much.
Paul
You have to replace the production WinSCP with the debug one.
DaveR
Spurious ? character introduced
I am also using an SSIS package which OCCASIONALLY inserts a '?' into the first winscp> command causing 'Unknown command'. This causes the package to technically fail (although the file is still downloaded from a remote server successfully). The scheduled SQL job (run each evening) marks it as a fail which is a pain as we have to check it just in case the failure is for a different reason. If there is any pattern in when the ? is inserted it always seems to be on a Sunday when some weekly database admin tasks Including on the SSISDB) take place earlier in the day. But this could be a complete red herring.
In the last 2.5 years since the problem was first reported, Did you ever get to the bottom of why this '?' character is SOMETIMES introduced and how to rectify it? I'm on WinSCP 5.9.2 Build 6958. Thanks.
Re: Spurious ? character introduced
It does not look like WinSCP question. You should probably ask on SSIS-related forum.
